Shorter final drive ratio
Lower final drive ratio
Based on the specs released by Acura, it looks like the gear ratios for the 2G TLX is identical to the 3G RDX, but with a lower final drive. This seems to suggest the 2G transmission will be the same, just with a different diff.
A lower final drive ratio means a higher top speed but less torque to the wheels, right? I wonder what that'll mean for the acceleration numbers... I guess at least this means freeway MPGs should be better since the engine will be spinning at a lower RPM for the same speed (edit: just noticed the EPA rating is out, and it's 22 city / 31 hwy, so same hwy as the outgoing V6 and 2 better in the city, and 1 less in both than the lighter Accord 2.0T which makes sense).
RDX: https://assets.acuratrainingguide.co...TURES_v2_0.pdf
TLX: http://www.urvi.net/forumfiles/SB/20...20Features.PDF
Edit 2: Dang I meant lower final drive in the title, not shorter. Shorter would be a higher final drive. If a mod could help update that to avoid confusion, that would be swell
They might have engineered the difference in the final drive ratio to compensate for something else (weight, aerodynamics, rolling resistance, etc) but the perceptible difference to the driver will be negligible.
What will be interesting is how they’re going to “beef up” the transmission for the Type S.
The RDX and TLX roll on different diameter tire/wheel (just used the standard tire/wheel, assuming someone at Honda matched up the
Tire/wheel
RDX 19" + (235mm*0.55*2/25.4) = 29.17" diameter
TLX 18" + (235mm*0.50*2/25.4) = 27.25" diameter
Final drive to force calculation
TLX 3.69 / (27.25/(2*12)) = 3.25 pounds of force at tire contact patch per ftlb of final drive torque
RDX 4.17 / (29.17/(2*12)) = 3.43 pounds "
TLX/RDX 3.25/3.43 = 0.948
So if my math is right the TLX will have a ~5.2% lower force at the wheel from final drive/tire diameter overall compared to a RDX with the same torque. Since they have the same engine/transmission then that is a overall diff in torque multiplier
Tire/wheel
Tire/wheel
TLX 3.59 / (27.25/(2*12)) = 3.16 pounds of force at tire contact patch per ftlb of final drive torque
TLX/RDX 3.16/3.43 = 0.921
So if my math is right the TLX will have a ~8.2% lower force at the wheel from final drive/tire diameter overall compared to a RDX with the same torque. Since they have the same engine/transmission then that is a overall diff in torque multiplier
Tire/wheel
AcuraGuy2016
3G RDX (2019+)
179
Nov 14, 2021 09:41 PM
neoshi
Jul 27, 2019 08:06 AM
