Oil Change
Oil Change
Hi wanted to confirm oil filter and ask what oil you guys use. 23 tlx type s here my first oil change was done at the dealer, they give me 2 a year, I drive hard and a lot so will be doing another one soon wanted to ask what oil you guys use/recommend as well as confirm if this is the right filter. Not very straightforward info when looking it up unless I’m just being dumb.
oil filter:
oil filter:
That's "the" Honda/Acura oil filter that every model has used for years (exceptions being the S2000 and NSX).
The A02 replaced the A01. Many Honda gearheads thought the A01 was better, so those go for a premium if you can still find them. I'm sure the A02 is fine as well as long you're changing them at least every other oil change.
I buy 6 at a time. Make sure to get the crush washer for the drain bolt. They're cheap and usually available from the parts sites when you order the filters.
wdmacura (08-05-2024)
awesome thank you so much I see a bundle on Amazon with the washers for 3 of them will probably go with that.
what if i told you that Amazon comingles all inventory in their warehouses from different sellers such that counterfeit items would fall into that same bucket of items being “sold by a honda dealer”
Baksju (09-29-2024)
The filters were shipped form a Honda dealer. Not from an Amazon warehouse.
I agree with @thoiboi on commingling possibility
Amazon regards the products as fungible (it's an actual legal term), meaning that a filter made by brand xyz and labeled as Honda, is the same regardless of who is selling it. Further, if a warehouse in Brooklyn runs out of stock of the filter, the order may be filled from a warehouse in Harrisburg PA, again regardless of who has supplied the filters in any given bin.
So the buyer needs to use caution in purchasing these small commodity items; you may not know what you get, until you get it!
Honda of America at the Corporate level purchases thousands, perhaps millions of filters every year, and they purchase them direct from their source in Japan. They are then disseminated downward to the individual dealers, Honda parts suppliers, etc. based on the Honda inventory system. There isn't any unknown middle person, the filter is supplied from Honda (Japan) to Honda of America to the local Honda dealership. The odds are much higher in this scenario to get the genuine Honda filter.
This was well documented back in 2014 by many sources, one at The pros and cons of commingling for Amazon merchants. Whether it holds true today, and specifically with respect to Honda filters, remains an unknown. But buying the filter from a dealership or from the online dealer related vendors seems to be a better path.
H...at any given Amazon warehouse are placed in the same stock bin and the computer simply handles who made the purchase and a robot (most likely) draws the filter from the bin at time of purchase. But in this example, you have 50/50 chance of getting a counterfeit filter..
Probably, but go to https://www.hondapartswholesaledirec...er-15400plma02 and verify.
[QUOTE=slowlyspeeding13;16944070]Hi wanted to confirm oil filter and ask what oil you guys use. 23 tlx type s here my first oil change was done at the dealer, they give me 2 a year, I drive hard and a lot so will be doing another one soon wanted to ask what oil you guys use/recommend as well as confirm if this is the right filter. Not very straightforward info when looking it up unless I’m just being dumb.
oil filter:
QUOTE]
I only use Honda filters and Royal Purple Oil......
oil filter:
QUOTE]
[QUOTE=TypeSbuilder;16955256]
I use full synthetic and filters from WalMart for my 07Type-S w/240k miles and my 22Type-S. I do my own changes btw so I save $40 a change.
oil filter:
QUOTE]
oil filter:
QUOTE]
[QUOTE=GhostTL09;16955266]
Same! I’ve used supertech synthetic for 7-8 yrs now on 6-7 cars I chg the oil for (my cars plus my daughters cars) and never had an issue.
Here’s a picture of my daughters 14 Accord 2.4L when I had to chg her valve cover gasket due to a faulty pcv at 112k miles. Used ST synthetic most of its life.
14 Accord 2.4L
14 Accord 2.4L
[QUOTE=PLP-94;16955373]
14 Accord 2.4L
Nice! That looks clean.
My brother put me on to it about 5 years ago. No issues at all.
14 Accord 2.4L
Now how do you think that Acura can get 50.4 mpg by 2031? Certainly engine design can be a key factor, but truth be told the engines are pretty sophisticated and anything moving forward would likely impact cost tremendously. Having said that the governing body that sets the CAFE doesn't care much about your wallet. Other factors include oil viscosity. The impact may be quite small but a multitude of small increases can add up. Those numbers of economy that are on your windows sticker are derived on a test stand. However the vehicle is configured on the test stand, has to essentially be in accordance with the recommendations. So you can't test with 0W-20 and put in the manual the preferred oil is 5W-30. The 5W-30 can be indicated as an alternative but the preferred or required product has to essentially be the way the vehicle is tested. Some factors may seem relatively insignificant. I suspect by your choice of word "cool" that you are relatively young. It is too bad you didn't grow up in the era of the Mobil Economy Run (see Mobil Economy Run This was an "event that ran from 1936 to 1968, long before our gov't tested vehicles for economy. FYI, the window sticker indicating mileage didn't appear until the mid-1970's. The idea behind the Mobil Economy Run was to establish the economy of a vehicle under typical driving conditions encountered by average motorists. As a teenager and young adult I loved to follow the event. My father watched with high interest because he drove about 50,000 miles a year. But drivers used a lot of tricks we don't think of; the radio was always off, no headlights unless absolutely needed, no wipers unless absolutely needed, no heater unless absolutely needed, higher than normal tire air pressures, weight reductions, etc. The cars were equipped with manifold vacuum gages because it had been determined that when going up hill, constant vacuum was better than constant speed. So you might hit a hill at the bottom at 30 mph, and hit the crest at 20 mph and of course coast downhill. . . .
So why does Mexico suggest a more viscous oil which can decrease mpg? Because as of 2019 their equivalent to our CAFE was 7.6 Liters/100 km. Now we are going metric, just doing it inch by inch by if my math is correct that is just short of 31 mpg. So as you can see an oil that might result in higher gas consumption but be better for the engine is of less concern.
The following 2 users liked this post by John from PA:
jaywmtl (10-02-2024),
russianDude (10-02-2024)
Xtremespeed2102
04-04-2006 04:54 PM
