the NHTSA is now officially investigating transfer case failures...
Just a friendly reminder that if your transfer case fails, please report it to the NHTSA. The more reports they receive, the more likely we can get a long-term fix or at least an extended warranty.
https://www.nhtsa.gov/?nhtsaId=DP26001
NHTSA Action Number: DP26001
Components: POWER TRAIN
Opened From: March 6, 2026 – Present
The Petitioner cites 48 complaints received by ODI alleging the same failure. ODI will evaluate these complaints to determine if they are related to the failure cited in the Petition and will conduct a technical review under 49 CFR Part 552.
This Defect Petition is being opened to evaluate whether to grant or deny the Petition. The Petition can be viewed at NHTSA.gov under NHTSA Number 11712885.
Summary
The Office of Defects Investigation (ODI) received a Petition dated January 9, 2026, requesting an investigation into the loss of the optional all-wheel drive capability in model year (MY) 2021-2023 Acura TLX and MY 2022-2023 Acura MDX vehicles. The Petition contends that the interfacing splines between the transmission and the rear wheel drive power take off unit are failing. Failure of these splines prevents the transfer of drive power to the rear axle, making the vehicle front wheel drive only. The Petition further alleges that this failure results in a reduction of vehicle directional control.The Petitioner cites 48 complaints received by ODI alleging the same failure. ODI will evaluate these complaints to determine if they are related to the failure cited in the Petition and will conduct a technical review under 49 CFR Part 552.
Regarding the transfer cases, the TSA has launched an investigation. A search found several articles like this one:. https://www.carscoops.com/2026/03/do...ls-are-enough/
Acurasince2009
Jun 18, 2024 05:21 AM
05rocket
Jul 20, 2010 06:11 PM
