2018 A-Spec Wheel Spacers
Hi Guys,
Has anyone used some high quality wheel spacers on the 18 A-Specs yet and if so which did you go with exactly?
Id like to push my wheels out to the fender lips but not sure that is to much for the stock lugs?
I wanted to lower my TLX but I want the stock ride so I will do the spacers to get a slight lowering look hopefully.
Can you guys share what MM, brand, part number etc as well as a pic maybe?
Registered speed offender
Hi Guys,
edit: adding wheel spacers will likely not give the illusion of being lower than stock. in fact, it may show the fender gap even worse due to the tire being outward closer to it.
