Won't shift into gear, every sensor code
Old Aug 21, 2018 | 10:19 PM
canadian_cop's Avatar
9th Gear
First problem, and it's a big one
Have owned my 2018 A spec for a few months.
Had a fun drive. Parked it for a few hours. Got back in and started it.
Every sensor warning started popping up. Mirrors were delayed on moving out. Seat finally moved.
Then I discovered car would not shift into drive, reverse or even neutral. Singing as if door was open.
Almost wouldn't turn off.
Tried resetting all settings.
disconnected battery for 5 Mins.
Started it a few more times.
Nothing helped.
After being towed to local Honda dealer, had them run any tests they could do. Couldn't find anything that was helpful. Sent to Acura dealership on flatbed.
Good thing: continued to do same faults not making me look like an aHole as vehicles can do.
But ive gone back on thread and see wheel speed sensor has been a culprit. Battery shouldn't be an issue with less than 11000kms on it.
Homda said battery checked out (if the actually checked it)
some previous videos of this are exactly what I'm seeing...except being stuck in park
what do you think? I want to guide dealership to cut down wasted time while I'm without car
Old Aug 21, 2018 | 10:24 PM
Speed_Racer's Avatar
6 Forward 1 Back
Might be a blown battery fan that's happened to a few others. Something about the fuse there causes the dash to light up like a christmas tree and you have to have it towed because you can't shift it out of gear like you're seeing. No idea if it's the same issue, but sounds like it.
Old Aug 21, 2018 | 10:28 PM
9th Gear
awesome. Thank you. Will send this to tech and see if they resolve with this info
thank you
Old Aug 21, 2018 | 10:38 PM
6 Forward 1 Back
You're welcome. Hopefully that's the only issue. Check this video out:
Open it directly on YouTube to see the comments.
Old Aug 21, 2018 | 10:52 PM
9th Gear
Yessir. That's what's going on. Flashing gear and all.
I hope that's it as well.
Happy I joined this group. Shared so
e screenshots with tech. He's likely going to think I'm a douche or grateful that I'll make him look like a genius because of your info lol
adominguez7
Sep 12, 2007 12:17 AM
Echen951
Dec 7, 2006 10:03 PM
Nicky Pass
Sep 16, 2003 05:55 PM
