Traction control
Old Jun 24, 2018 | 04:18 PM
ultrapogi's Avatar
Traction control
Can anyone confirm if traction control cannot be fully turned off? I had it off the other day and accelerated hard into a left hand turn and the traction slip light indicated and the power cut for a second.
Old Jul 19, 2018 | 08:58 AM
mikedub88's Avatar
You can use the procedure in this video. This is done on an ILX but it will work for the TLX.
Old Jul 24, 2018 | 11:50 AM
ultrapogi's Avatar
Awsome. I can confirm this works on the AWD TLX. You have to do it exactly as shown(except the electronic brake button instead) it does continue to blink so if that annoys you. I will try for a while and seen if I notice a difference with my driving style. Probably won’t notice it unless I am driving on the limit.
Old Jul 25, 2018 | 06:59 AM
TSXV6Guy's Avatar
Here's the official text version - it's called "entering VSA maintenance mode".
  • When the VSA Maintenance Mode is activated, the VSA and TCS functions are disabled.
  • During the Maintenance Mode, the VSA OFF indicator flashes and the VSA indicator is on.
  • When the vehicle is turned to the OFF (LOCK) mode or the VSA OFF switch is pressed again, the Maintenance Mode is cancelled and both indicators go off.
  • If you do not properly follow the steps to enter the VSA maintenance mode, or you do not complete the procedure within 30 seconds, turn the vehicle to the OFF mode, wait for 10 seconds, and try again.
  • When the VSA detects a malfunction, the Maintenance Mode is cancelled.
  1. Turn the vehicle to the ON mode and do the following procedure within 30 seconds.
  2. Release the parking brake and hold down the brake pedal.
  3. While holding down the brake pedal, press and hold the VSA OFF switch. When the VSA OFF indicator turns on, press and hold the VSA OFF switch again until the VSA OFF indicator goes off.
  4. Release the brake pedal and apply the parking brake.
  5. While the brake pedal is released, press and hold the VSA OFF switch. When the VSA OFF indicator turns on, press and hold the VSA OFF switch again until the VSA OFF indicator goes off.
  6. Hold down the brake pedal while apply the parking brake.
  7. Press and hold the VSA OFF switch while both brakes are applied. When the VSA OFF indicator turns on, press and hold the VSA OFF switch again until the VSA OFF indicator flashes and the VSA indicator turns on.
Old Jul 26, 2018 | 12:13 PM
9SpeedTran's Avatar
What kind of tires do you have?
Old Jul 28, 2018 | 12:31 AM
ultrapogi's Avatar
245/35ZR-20 CONTINENTAL EXTREMECONTACT DWS 06 XL
They grip extremely well.
Juker008
Oct 8, 2008 10:06 PM
Juker008
Sep 7, 2007 02:19 PM
uzzmaan
Motorsports News
Apr 6, 2007 03:52 PM
gavriil
Oct 29, 2003 01:29 PM
PiMpIn2.2CL
Nov 16, 2001 12:00 AM
