Service schedule?
Service schedule?
Anyone know if there’s a service schedule to ‘18 TLX?
cannot find anything on google.
im hitting 36000, oil changes done. Air filter and such as well.
but usually there’s a set schedule to preserve warranty with other brands I’ve owned.
Follow the maintenance minder, i.e., your dash will tell you. For my TLX, A or B service was required about every 10k miles (16k km). Then a whole bunch of ancillary checks and changes are thrown in. That's when you see stuff like A15, A16 or B123.
Google "maintenance minder table" if you want a guesstimate on what to expect at what mileage.
Like someguy11 said, the maintenance minder will tell you when to do what, for the most part. The codes it shows can be found in your owners manual. Or you can find the codes here : https://owners.acura.com/service-maintenance/minder
Most dealers will try to get you to do oil changes, transmission fluid changes, etc, when they're not called for and when your maintenance minder notifies you to do them again, you do it again for no reason. For the most part, just stick to the maintenance minder.
