no heat
upset (01-04-2016)
It has been looked at by two dealers a total of 7 times for this issue, I been in other TLX's and no problem. I have to stop about every 30 miles if I'm going 65 mph to warm up the cabin
put it at Auto 81 degrees. If it's not on auto it can't control it. Don't tweak the vent settings. The heat will come from the floor much more from the upper vents. Upper vents supply A/C that is on to help control humidity.
Summer is Coming
could be a failed damper behind the dash.
Take it off Auto and set it to push air out of both vents - you should feel a steady stream of warm air.
I don't know who tested the "Auto" setting but IMO it's not the best.
CPR (01-06-2016)
Registered Abuser of VTEC
I dunno, my auto setting is fantastic (and it gets very cold here, converting for you Americans it was -14F yesterday). The auto setting automatically swaps between defrost and warming you up. I have the cabin temp set at 25 C and it keeps it nice and warm, and doesn't blast me with cold air before it's warmer than what's already in the car. I leave everything, including the seat heaters, on full auto mode and I find the logic to be quite good.
I take it OFF AUTO, because above 32* F the A/C compressor comes on
Not necessary, & a waste of fuel, in the winter; I have mine split between Heat, & Defrost vents, & temp at 72*. make sure the fan speed is set to Auto, & the sync mode is on, unless the passenger likes a different temp.
In the Spring, & Summer,FULL AUTO is the preferred mode
I have not noticed the A/C coming on, but I believe there is logic built into the system to periodically engage the A/C compressor to keep it lubricated. It may have been the handbook from the 3G TL that said the A/C should be turned on regularly over the winter for this effect.
Summer is Coming
Right - that's the thing I don't like about it. Once it gets the cabin to the correct temp the AC/Defrost cycles on and off which has the effect of blowing cool air around your upper body. My wife (granted she's a freeze-baby) complains about it all the time so I turn AUTO off.
This is a stupid characteristic of the system when on auto. not bothering me now as my commute is so short it doesnt get to the point where it starts throwing cold air at you. it should stay on feet and warm. If I need it on the shield I can press a button (or more in the case of the TLX's convoluted touch screen).
There's also the risk of getting "the stink" from leaving it on AUTO as noted in the RLX section:
click -> https://acurazine.com/forums/third-g...-vents-935449/
