My tlx is going into limp mode
Old Aug 12, 2021 | 08:39 AM
2015acura's Avatar
3rd Gear
Long story short the wife’s 2015 4 cylinder TLX is going into limp mode when under a heavy load like going up a long hill on the highway or hard acceleration / high cruising speed.
when it goes into limp mode the engine light flashes and the car has no engine power. I have to pull over, shut it off. When I turn it back on it’s totally fine and drives normal
no CEL and no stored codes in the computer
ive checked the obvious like oil and air filter but both are new. I did them 2 months ago.
many ideas where to start? I was thinking a failing fuel pump.
The car has 80,000 miles
thNk you
Old Aug 12, 2021 | 11:26 AM
flashing check engine light indicates a misfire condition.
if it's misfiring, it makes sense that there is no power for acceleration.
Old Aug 12, 2021 | 11:53 AM
2015acura's Avatar
3rd Gear
any ideas on what’s causing the misfire?
Old Aug 12, 2021 | 12:07 PM
could be bad fuel.
could be faulty spark plugs.
could be faulty coil packs.
I would start by troubleshooting the coil packs. With the engine running, I would disconnect the connector from the coilpack to the wire harness, one by one. the engine note should change. plug it back and move on to the next coil pack. if the engine note does not change, that's the faulty coil pack. troubleshoot even further by swapping the coil pack with a known good one...issue should follow the coil pack. lets say #3 is faulty. swap it with #1. if problem follows to #1, then that is def. the faulty coil pack.
if coil packs are good, I would move on to spark plugs.
Old Aug 12, 2021 | 01:13 PM
2015acura's Avatar
3rd Gear
could be bad fuel.
10/4 thank you I’ll try that when I get home
Old Aug 19, 2021 | 11:18 AM
any updates?
Angrybear
Jul 28, 2019 05:10 PM
noynek
1G TL (1996-1998)
Apr 25, 2018 09:29 AM
_Camus_
Jan 31, 2016 05:49 PM
MicroBurstGreen
4G TL Problems & Fixes
Dec 26, 2012 07:09 PM
wilsonjg
1G CL Problems & Fixes
Jun 15, 2006 08:46 PM
