My driver window auto up/down doesn't work
Old Sep 17, 2014 | 01:24 PM
insanik's Avatar
All other 3 windows work...
Is there a way to make it work again. It worked ONCE. Went to press it back up and now it doesn't work anymore automatically. just goes for as long as i hold it for.
Any thoughts what I can do?
Old Sep 17, 2014 | 01:40 PM
there is a reset option for the 3rd gen TL.
there might be a reset option for the new TLX to get your window to roll down.
read the manual, maybe.
Old Sep 17, 2014 | 02:07 PM
miner's Avatar
Previously it was roll all the way down, roll all the way up and continue to hold up button for 5 secs.
Old Dec 14, 2014 | 03:00 AM
mogriff1's Avatar
I am currently experiencing this issue. I recently had my windows tinted so I thought that would've caused the problem but no door panels were removed and tint was computerized cut. At first the driver's side window would only go up/down in short increments. I took it all the way down to the base and now it goes up/down in a smooth/continuous flow-but only if I keep my finger on the lever. Insanik was your issue resolved?
Old Dec 14, 2014 | 08:10 AM
heisnuts's Avatar
To reset the window, start with the window closed.
Push and hold the switch in the auto down position and keep holding the switch all the way down for 5 seconds after the window has opened all the way.
Now pull and hold the switch in the auto close position and keep holding for 5 seconds after the window has closed all the way.
The auto feature should now be working again.
Old Dec 14, 2014 | 09:53 AM
mogriff1's Avatar
Thank you for responding. I tried this method, however I still get the same results. The window will only go up or down continuously if my finger is pulling or pushing the lever. The window will go up or down intermittently if I stop/start the lever push or pull. I find it odd that I can get the passenger's side window to do a continuous up or down with pushing or pulling the lever twice and letting go.
I looked at my owner's manual (it appears that's the way it's supposed to operate???). P.158 Opening/Closing the Windows says:
Automatic operation
To open: Push the switch down firmly.
To close: Pull the switch up firmly.
The window opens or closes completely. To
stop the window at any time, push or pull the
switch briefly.
Manual operation
To open: Push the switch down lightly, and
hold it until the desired position is reached.
To close: Pull the switch up lightly, and hold it
Old Dec 14, 2014 | 11:38 AM
heisnuts's Avatar
The good news is if the reset procedure I listed does not fix the problem, it will be under warranty and your local dealer will be able to fix it at no charge to you (unless the tint shop cut something in the door that is preventing it from working)
AndrewS
19
Mar 14, 2024 06:59 PM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
dlknight
Sep 3, 2015 07:54 PM
