headlight adjustment
Old Aug 25, 2016 | 09:49 AM
kuzdu's Avatar
Styl1n
Hey guys, has anyone tried adjusting the headlight a little higher? as all of us know driving in the blackout areas its it very hard to see ahead. on my tsx there is no issues at all.
read your owner's manual it's in there
Old Aug 25, 2016 | 12:34 PM
kuzdu's Avatar
Styl1n
dont need any manuals im asking if anyone has adjusted them higher than factory settings. im thinking about doing it and i wanted some feedback from everyone
Old Aug 25, 2016 | 01:15 PM
and blind oncoming traffic?
go for it. I'm sure SOMEONE in the world has done so, that's not exactly unheard of..
or just ride around with the high beams on
Old Aug 25, 2016 | 08:23 PM
kuzdu's Avatar
Styl1n
Well I lined up my tsx with the tlx and lined them up wow what a difference now Its just like my tsx on the road.
Old Aug 26, 2016 | 07:15 PM
Sam Axe's Avatar
Use the high beam in those situations that is what they're for. It doesn't make sense to adjust the headlights permanently and cause glare to other drivers in other settings.
Old Aug 26, 2016 | 08:27 PM
RDX10's Avatar
Guys, he didn't say he was going to adjust his headlights to blind people on the road. He only said that his headlights are aimed too low. You guys are assuming they are aimed properly and he is going to aim them higher than that.
Clearly since his tsx is factory aimed, and he matched it to the factory aim on the tsx, how can he be blinding anyone?
I had a couple 2016 RDX loaners with the jewel eyes and I experienced the same thing OP is. EXTREMELY bright 10-20 feet in front of the car and garbage anywhere further. I was able to see the headlights on my light grey driveway during the day in bright sun light!!! So clearly light output is not the issue here.
Old Aug 27, 2016 | 09:34 PM
kuzdu's Avatar
Styl1n
thanks rdx10 you hit it right on the nail. It was pretty low now with the new adjustment to my tsx it's great much better than before. The service rep says a lot of people complaint about this as well.
Old Sep 1, 2016 | 03:54 PM
RDX10's Avatar
All good man. I had the same experience so I knew exactly what you were talking about. I wonder if it was intentional because LED's are harder to focus than HID's.
Old Sep 2, 2016 | 04:02 PM
cube1's Avatar
FYI, because of this thread, I marked the aim of my headlights on my TSX before I traded it in, then positioned my new TLX with its headlights at the same spot. The height was essentially identical.
Old Sep 2, 2016 | 09:18 PM
kuzdu's Avatar
Styl1n
mine wasn't it was lower than my TLX. Was yours an early or late build? Mine was a very early build and I matched mine to it and it's great. Not as great as the tsx projector. Maybe the early build headlights were a tad lower mine use to always show on the bumpers of cars now its bottom of license plate where the cutoff line is.
Old Oct 16, 2016 | 06:22 AM
Gremlin340's Avatar
5th Gear
Thumbs up 1/2 Turn on the adjuster
Had the same issue on my 15 TLX AWD Tech and was able to adjust up approx 1/2 turn on the adjuster and still be under the NH inspection target line on the garage wall. Made a big difference for me and I'm never flashed at by other drivers thinking I'm riding with the high beams on.
Old Oct 16, 2016 | 08:48 PM
cube1's Avatar
My TSX was built in June, 2016.
Old Oct 17, 2016 | 03:49 AM
Gremlin340's Avatar
5th Gear
My TLX is a mid 15 build, so it is exempt from the driveshaft indexing TSB (but still exhibits highway vibe that is not cylinder deactivation related) and has already had the transmission replaced at 26K miles. With the low beams adjusted up a bit, I am pleased with the lighting that I now get from the car. That pesky vibe is really the last issue that I have with mine... the trans replacement and new software have mostly resolved the evil shifting habits of the car.
Old Oct 17, 2016 | 08:33 PM
cube1's Avatar
D'oh. Make that TLX, of course.
Old Oct 18, 2016 | 07:53 AM
jswift2000's Avatar
I adjusted mine up a bit and its made a huge difference. Not only are the low beams better but the high beams actually illuminate the road. It took me a bit to get them just right. I think the hardest part was finding the right length screw driver.
MikeekiM
Aug 11, 2016 09:51 PM
maxguitars
2G CL Problems & Fixes
Jun 8, 2016 04:46 AM
nfnsquared
Jun 1, 2016 07:13 PM
mossman77
Apr 12, 2016 09:17 AM
Mr. Showtime
Mar 18, 2016 10:36 PM
