2018 TLX V6 A-SPEC FWD Transmission Issues
Old 05-02-2019, 09:29 AM
55lattery's Avatar
Took my 2018 TLX V6 A-SPEC FWD to the dealer this morning for oil A1 Service & State Inspection. While there I asked them to take a look at my transmission...I also went for a ride along with a tech.
Been noticing very violent shift pattern & I replicated the issue twice with the tech in the car, the vehicle would lurch forward and downshift hard in city-driving conditions when I was very light on the accelerator.
  • 1600-1900 RPM
  • 25-30mph
  • Gear 2-4
I used to own a 2010 G37x Coupe and I recall the technicians resetting the ECU & Transmission Computer + Installing Software patches. However today, my dealer said there are no software patches and no way to reset the transmission? I can't find a definitive answer on this forum as to whether or not this can actually be done on '18 TLXs, my dealer tech says it can't but my 8-year old Infiniti makes me think otherwise...
+ Bonus I just hit 32,500 miles on it and the dealer recommends changing my transmission fluid for $410.00 can anyone confirm they've seen similar prices? Seems high to me.
Old 05-02-2019, 01:07 PM
GhostTL09's Avatar
Change your own fluid if you can or go to an independent shop. At most they charge about $90. When really a transmission fluid change is the same as an oil change. $410 is outrageous
Old 05-02-2019, 07:05 PM
Rocketsfan's Avatar
1) Yeah, the dealership charge for the transmission fluid is more than on a 4-cylinder or past TL's/6-cylinders -- they use a more expensive ATF, apparently. I think most places are probably charging around $300'ish... not sure. Here's what EE4Life posted a couple of years ago : https://acurazine.com/forums/fifth-g...mation-925334/
2) Unless you drive in some mountainous terrain, you shouldn't need to change the transmission fluid yet. You stated that you went for an A1 service (assuming that's what the computer showed on your dash). If so, the time to change your transmission fluid is when the number is a "3" shows up on the MID. Check your owners manual. I think that code came up for me around 40-50,000 miles.
ablb454
14
04-12-2019 11:13 AM
princeo5
02-02-2019 07:50 PM
SupraJL
09-23-2018 01:44 AM
Katira
06-20-2018 08:25 PM
Sloppy305
05-15-2017 06:20 PM
Quick Reply: 2018 TLX V6 A-SPEC FWD Transmission Issues
