Help with AHA audio streaming
Old Mar 12, 2015 | 09:35 PM
quintno's Avatar
I just got my new TLX with the Tech package and was happy to see that it included the AHA app as one of its sources. I signed up at AHA website and set 10 internet radio stations as presets. I then signed up for AcuraLink and was able to connect to AHA through my iphone, and access these presets. The question I have regards changing preset channels once I access AHA as an audio source. There's no problem with hearing the first station on the app, but there's no way to access other presets, either through the screen, the dial on the steering wheel, or even on my iphone, which is simply frozen on the AcuraLink screen. There's no problem changing preset channels on the phone when I'm not linked to the TLX--but once AcuraLink takes over, only one channel can be heard. And even this one channel can't be preset on the car.
Any suggestions?
Old Mar 12, 2015 | 10:00 PM
quintno's Avatar
Just found a partial answer just a few threads down. Seems you have to click the star after each station in the AHA/AcuraLink app. Tried it and it worked--at least in terms of the stations appearing as presets on the lower screen. But still no ability to change them either through left scroll wheel on steering wheel or on first page of AHA screen. Only way to change is by pressing the "stations" button.
Old Mar 19, 2015 | 12:05 PM
open contact's Avatar
when you you stream AHA does iut use the data from my phone?
Old Mar 19, 2015 | 03:42 PM
Quandry's Avatar
Sure does. It is great for people with unlimited data plans.
Old Jul 31, 2016 | 08:45 AM
Wiseone's Avatar
7th Gear
The Aha application is not very effective. The Acura connection application works and connects automatically. But you can't use the the station presets on the screen in the car with out having to go to the Aha application and fumble with them to get the station you want to work.
its kind of a pain especially when u want to be hands free.
Anyone figure this e out? I have called Acura and Aha...no one has a solution other than blaming the other company for the issue.
Wiseone's Avatar
7th Gear
The Aha application is not very effective. The Acura connection application works and connects automatically. But you can't use the the station presets on the screen in the car with out having to go to the Aha application and fumble with them to get the station you want to work.<br />its kind of a pain especially when u want to be hands free. <br /><br />Anyone figure this e out? I have called Acura and Aha...no one has a solution other than blaming the other company for the issue.
Old Jul 31, 2016 | 03:16 PM
sbillard's Avatar
I am no longer using Aha, but if I recall correctly you need to set the stations you want as presets to "favorites" in Aha.
Old Jul 31, 2016 | 03:25 PM
Wiseone's Avatar
7th Gear
Yes the stations are preset and I see them on the screen on the car.
the issue is when I hit the station that's on the screen ...it just says processing....but never connects.
Old Aug 7, 2016 | 08:15 AM
Wiseone's Avatar
7th Gear
I guess no one knows why Aha doesn't really work . I don't know how Acura says that this is a feature but it's really just a broken reality.
Poor PR I think !
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
