Help with AHA audio streaming
I just got my new TLX with the Tech package and was happy to see that it included the AHA app as one of its sources. I signed up at AHA website and set 10 internet radio stations as presets. I then signed up for AcuraLink and was able to connect to AHA through my iphone, and access these presets. The question I have regards changing preset channels once I access AHA as an audio source. There's no problem with hearing the first station on the app, but there's no way to access other presets, either through the screen, the dial on the steering wheel, or even on my iphone, which is simply frozen on the AcuraLink screen. There's no problem changing preset channels on the phone when I'm not linked to the TLX--but once AcuraLink takes over, only one channel can be heard. And even this one channel can't be preset on the car.
Any suggestions? |
Just found a partial answer just a few threads down. Seems you have to click the star after each station in the AHA/AcuraLink app. Tried it and it worked--at least in terms of the stations appearing as presets on the lower screen. But still no ability to change them either through left scroll wheel on steering wheel or on first page of AHA screen. Only way to change is by pressing the "stations" button.
when you you stream AHA does iut use the data from my phone?
Sure does. It is great for people with unlimited data plans.
The Aha application is not very effective. The Acura connection application works and connects automatically. But you can't use the the station presets on the screen in the car with out having to go to the Aha application and fumble with them to get the station you want to work.
its kind of a pain especially when u want to be hands free. Anyone figure this e out? I have called Acura and Aha...no one has a solution other than blaming the other company for the issue. |
The Aha application is not very effective. The Acura connection application works and connects automatically. But you can't use the the station presets on the screen in the car with out having to go to the Aha application and fumble with them to get the station you want to work.<br />its kind of a pain especially when u want to be hands free. <br /><br />Anyone figure this e out? I have called Acura and Aha...no one has a solution other than blaming the other company for the issue.
I am no longer using Aha, but if I recall correctly you need to set the stations you want as presets to "favorites" in Aha.
Yes the stations are preset and I see them on the screen on the car.
the issue is when I hit the station that's on the screen ...it just says processing....but never connects. |
I guess no one knows why Aha doesn't really work . I don't know how Acura says that this is a feature but it's really just a broken reality.
Poor PR I think ! |
