Foot Area LED's
Old Aug 20, 2014 | 10:35 AM
scooterb84's Avatar
Foot Area LED's
So I have heard mixed opinions whether the foot area has illuminated LED's like past Acura's have had. I am seeing them in the door handles and center console but nothing by the feet. Is there a special setting or do they just not have those any more.
Old Aug 22, 2014 | 09:38 PM
bdwpac81's Avatar
I don't see any illumination in the foot area. My TSX had it but they must have left it off the TLX. I have an i4 Tech model.
Old Aug 25, 2014 | 08:19 AM
jayb082's Avatar
That sucks...especially considering their emphasis on interior/ambient lighting. On my TSX I used the wiring there to put in some awesome looking blue LED strips. Was planning to do the same for TLX :-\
Old Sep 21, 2014 | 11:41 AM
Alexboculon's Avatar
Ya, this was a disappointment. I'm coming from a 14 year old 3 series, and this is one of several ways my brand new acura is lacking.
Old Sep 21, 2014 | 01:44 PM
Gregg's Avatar
Definitely a shame. I used that lighting in the TSX to determine if my right foot was on the brake or the gas. ;-)
Old Sep 21, 2014 | 04:00 PM
slats's Avatar
This would be very easy to add- $5 and half an hour maybe. If in end up buying a TLX I will deff be adding the ambient footwell lighting. Also thinking about modding the rear door handles to light up as well- although that's gonna be slightly more complicated.
Old Sep 23, 2014 | 12:24 PM
jayb082's Avatar
The more I drive at night, the more I miss the foot well LEDs. I want to put some in. For the drivers side, it should be easy as I can just use the nearby fuse box for power. Any ideas on how to do the passenger side without too much trouble?
Old Sep 23, 2014 | 12:35 PM
Timmy18's Avatar
Do it! Pave the way for us with a DIY and pics!
Old Sep 23, 2014 | 12:36 PM
Stew4HD's Avatar
I should think that it would be an easy job to run the driver's side in series with the passenger side once you pop out the footwell panels out. A coat hanger should pass behind the console with little effort to get the wire across.
Old Sep 23, 2014 | 12:40 PM
CheeseyPoofs McNut's Avatar
I wonder if you could modify this to work:
click -> Interior Ilumination (except Sport) - 08E10-T2A-100A - College Hills Honda
Old Sep 23, 2014 | 12:44 PM
Stew4HD's Avatar
^great find!
Old Sep 23, 2014 | 03:15 PM
slats's Avatar
I don't have a TLX yet :-/. But I did this in my 04 TSX and it was easy. Blue pre wired LEDs from superbrightleds.com and wired into any lit switch. On the TLX I would most likely tap into the wires that light up the little consol tray
Old Sep 26, 2014 | 01:57 PM
Well, they should be wired to only turn on with the overhead lights, ideally fading gently in and out as well. You'd want to find the wire heading to the dome light itself, I'd think, as the only way to make that happen.
Perhaps you could identify the specific dome light wire to splice into from the fuse box and follow it, but I am skeptical it would be easily accessible (i.e. right under the glove box or something), and I don't want to be cutting new holes in the firewall to wire it myself. Either way, this sounds like more than 30 minutes of work.
Old Sep 26, 2014 | 03:18 PM
jayb082's Avatar
I bought 2 blue LED strips a couple days ago with the hopes of installing them. It'll be a few more days till I get them. The driver's side is somewhat easy - there's a fuse box there. Ideally I'd like to have it wired so they turn on when the headlights do but it seems the headlight fuse is in the engine bay - any other options? The passenger side seemed a bit tougher. I found various wires under the dash but not quite sure which one to use - any ideas?
Old May 2, 2015 | 11:14 PM
alexxn's Avatar
Has anyone tried to retrofit this kit ?
Old May 3, 2015 | 06:29 PM
Hoosier_TLX's Avatar
I'll admit that I wouldn't mind having a little more ambient lighting. I do love the way my CTS has the subtle white "theater lighting" around the dash and the footwells. I may at some point try to add some lighting, but it's not a major area of concern for me.
Did anyone try to get that accord lighting accessory? It looks like it would probably work, but the installation looks a little time consuming.
Old May 4, 2015 | 07:24 PM
DrInvincible's Avatar
I've been installing footwell LEDs as a DIY-er and it is generally pretty straightforward. Hopefully the TLX is the same since drilling new holes would be like drilling my heart
quanaman
Jan 9, 2023 07:33 PM
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
knight rider
Mar 4, 2016 08:59 AM
lanechanger
Oct 13, 2015 10:56 AM
eastcoastguy
Sep 23, 2015 06:29 AM
