Bluetooth Calling Problem
Old Oct 29, 2015 | 05:54 PM
doug418's Avatar
I just got my 2015 TLX 3.5 tech last week upgrading from a 2013 ILX. I'm having problems with making calls using the bluetooth in the new car. I have a Galaxy Note 4 and paired it just fine. I'm able to play audio from my phone but when I make calls the recipient can't hear me. I can hear them just fine but they just can't hear me. I have to transfer the call to my phone so I can have a phone conversation. I had a little bit of luck with unpairing and then re-pairing. The person on the other line could hear me, but after a few minutes would complain that I sounded like I was in a wind tunnel and then eventually they wouldn't hear me at all. Keep in mind, the phone didn't move, windows rolled up and AC off. It's really frustrating. I don't think it's a phone compatibility issue because it worked fine in the ILX which I'd imagine was running the same, or older firmware for the bluetooth. Any suggestions before I bring the car back to the dealer for them to look at?
Side note - The handfreelink voice prompts dont seem to work either. Could be a problem with a microphone or something??
Old Jan 24, 2016 | 09:48 AM
Pearlsmomma's Avatar
3rd Gear
Same Bluetooth calling problem
Hi, thank you for posting this problem. Glad to see I'm not the only one. Same thing, I can hear the person on the phone,but they can't hear me. (I did not hit the mute button either). This problem is intermittent, and when I took it to the dealer, it wouldn't duplicate. Of course, now it's doing it again. Did you find a fix for this issue? Thank you.
Old Jan 24, 2016 | 04:59 PM
youngTL's Avatar
Registered Abuser of VTEC
I think it has to do with playing audio from your phone. I don't know why it gets confused about it but seems to.
In any event, with the ELS system, I much prefer to play music over USB, the quality is much higher than with bluetooth.
Old Jan 25, 2016 | 08:43 AM
doug418's Avatar
Fix
So apparently there is a separate volume control for Bluetooth/navi voice. I took to the dealer and they took about an hour to figure out that the secondary volume was turned down so people couldn't hear me when talking. There is a volume control for bt in settings and I think you can also use the volume control while on a bt call. Give it a shot and see if that fixes the problem for you. Pretty simple but I never would have figured it out on my own.
spedprof
5G TLX Problems & Fixes
Mar 3, 2017 08:05 AM
Kiya
17
Feb 26, 2017 07:50 PM
ddjruch
Oct 29, 2015 11:59 AM
scottsan
Oct 28, 2015 09:23 PM
Hardhotel352
88
Oct 24, 2015 09:44 AM
