3g CDMA network imminent shutdown
Old Sep 18, 2021 | 06:14 PM
  #41
Jim2301's Avatar
Kudos to Ethlar!!
Instead of bitching and whining about the issue he went out and tackled it head-on. If we're smart we all can learn from his initiative.
You other folks who are impacted by the laydown of 3G might consider quickly following his lead BEFORE the newer modules become scarce and/or potential sellers figure out the true value of their "surplus" modules.
Well done, Sir!
Old Oct 19, 2021 | 01:15 PM
  #42
9SpeedTran's Avatar
Upgraded ALink Device
Originally Posted by wstagner
How To Continue Using AcuraLink Subscription Services
You may continue to access your AcuraLink subscription services
if the hardware in your vehicle is updated with a new device.
Please contact your dealer for more information.
I will post here when I get more info.
I called my dealership parts dept after getting the notice and they had no clue what I was talking about and could not identify a replacement in the parts catalog. I figure I will try again when I bring it in for maintenance at the end of this month. What is weird is that now the nav system shows these little white dots that look almost look like tiny cars on the routes. Anybody else see that, and know what that means? :-)
Old Oct 19, 2021 | 02:15 PM
  #43
instead of asking the parts department, give them the part #.
that way, they can't "not know" what you're talking about.
the conversation should go something like this:
"hi, just wondering if you have this part # in stock."
you can try either of these part#'s
39770-TZ3-A61
39770-TZ3-A53
however; it's going to be expensive.
$800-1200
I would do exactly what Ethlar did...check ebay or check junk yards
used units will be just as good.
Old Oct 19, 2021 | 06:04 PM
  #44
9SpeedTran's Avatar
I think those are the Hands free units
39770-TZ3-A61
39770-TZ3-A53
$800-1200
Not sure those are the right parts but thanks!
Old Oct 19, 2021 | 06:10 PM
  #45
I crossed checked with parts diagram and the user Ethlar bought one....
they are indeed the correct part #'s for the telematics unit or the hands free unit.
Old Oct 20, 2021 | 01:16 PM
  #46
wstagner's Avatar
Nice work, Ethlar.
You're an inspiration to us all.
Old Jan 8, 2022 | 11:51 AM
  #47
DouglasM's Avatar
not all 2017 models are affected
Check you 2017 tlx on the Acuralink website
Not all 2017 models are affected. I got lucky
Old Mar 5, 2022 | 08:26 PM
  #48
ThaChadwick's Avatar
Replaced myTelematics Bluetooth HFT device. I was able to locate a blue labeled LTE HFT and swapped it out. Map data pulls up almost instantaneously now with the new device. Green light shows. My AcuraLink subscription shows up in info settings.
However, my vehicle does not refresh on the AcuraLink app, nor does the emergency assist button overhead recognize my AcuraLink subscription. Anyone run into this issue?
Old Mar 7, 2022 | 05:34 PM
  #49
Update: Contacting AcuraLink Client Services or In Car Technologies doesn’t work. Multiple reps said they couldn’t update the serial to associate to my AcuraLink account and that the dealer would need to handle. The service department at my dealer isn’t sure either and is researching. Reflashing HFL in diagnostics mode fails.
Old Mar 7, 2022 | 05:47 PM
  #50
ethlar's Avatar
i would cross check that the unit you sourced is correct for a TLX, also where did you source it? if it was used its entirely possible it was pulled from a vehicle for acting up
Old Jan 4, 2023 | 01:15 AM
  #51
CAB NY's Avatar
Tri State ViP Crew
does anybody know if these would work I found
39770 TZ3 A610 and A611 thanks The one posted is 39770 TZ3 A61
2015 6cyl Tech
Old Jan 4, 2023 | 07:11 AM
  #52
ethlar's Avatar
39770 TZ3 A61 might work, but it looks like its for the 2018 refresh and up. With all the other electronics changes in the refresh it might be incompatible.
Old Feb 10, 2023 | 11:30 AM
  #53
janski's Avatar
AcuraLink connectivity after installing new telematics unit
Hi. I had the new telematics unit (TCU) installed on 1-17-23. I had ordered the unit in May 2022 and it was back-ordered forever.
The installation went smoothly, but the AcuraLink connectivity had a few hiccups. On 1-18-23, I phoned AcuraLink to restart my subscription. They renewed it and my AcuraLink mobile app showed a new expiration date of 1-18-2025. However, no remote commands would work, and no vehicle data (odometer, tire pressure, etc.) would populate on my mobile. Pushing the Remote Assist button returned a message of, "You need to sign-up for the service". The AcuraLink status in my car showed the subscription lapsing on 7-1-2022. I asked dealer if AcuraLink needed the new unit number, which the dealer admitted they did not record from the new device. I went back to the dealership and they re-opened my car to get the TCU IMSI number. Between the dealership and AcuraLink Customer Service, no one seemed to know how my VIN number became associated with the new TCU number. Service manager then opened a case with Acura Corporate. We began going in circles, then I asked to talk to AcuraLink Tech Support. They had the answer - have your Service Manager call AcuraLink Customer Service, ask for Tech Support, then ask for a supervisor. Give supervisor the VIN number and new IMSI number and the supervisor will change it in the database. Even though I had the TCU IMSI number, I was not authorized to request a database update.
I am happy to report that as of 2-2-2023, everything is now working. AcuraLink even added a month to my subscription. I discovered later that this was the first TCU upgrade that my dealership had done. I was the guinea pig.
Old Mar 30, 2023 | 10:53 AM
  #54
CAB NY's Avatar
Tri State ViP Crew
Thanks for the information from (ethlar) and the (Chadwick) it was a easy fix just find the telematic ending in 53 or 530 blue label on eBay or you can find it for about 800$ online the dealer price is worse I was told about 1400$ and up plus installation over 2000$ I removed the glove box and took about 15 minutes to install and called Acuralink and was back in business
Old Mar 30, 2023 | 11:00 AM
  #55
CAB NY's Avatar
Tri State ViP Crew
How much did the dealer charge
Old Mar 30, 2023 | 12:08 PM
  #56
janski's Avatar
The dealer charged $1216.32 ($1339.17 with tax) for the telematics unit (TCU). The installation of the unit was $191.50 (before tax). My dealer said they would only install a TCU purchased from Acura.
Also, not sure how people are getting AcuraLink to reconnect to a replaced TCU. I spoke with AcuraLink tech support multiple times, and they said they needed an Acura Service Manager to make that request.
1fstTL
Jan 30, 2013 12:37 AM
pohljm
May 17, 2012 01:40 PM
Moog-Type-S
Technology
Feb 19, 2012 07:07 AM
Professor
Technology
Mar 31, 2010 01:54 PM
06_TL
Oct 7, 2009 08:37 AM
