2019 TLX add a circuit
Old Oct 2, 2019 | 08:45 PM
Blade21's Avatar
Hey guys,
I need your help here. I'm installing a dashcam and I'm using an add a circuit fuse. When installing this add a circuit to the auxillary or the cigarette lighter, after turning off the car, the dashcam is still on. I've tried another aux fuse and its the same thing.
Question is what slot did you guys use for the add a circuit for a switched power supply? It seems that whatever slot I use the power is still on. I have another way to go about this but its my last resort to tap into the cigarette lighter wires. If anyone has take apart either lighters, I would like some insight on this.
Thank you in advance!
Old Oct 4, 2019 | 12:17 PM
natkhat's Avatar
I experienced the same and after trial & error, I had decided to use parking fuse, not sure the # but it works fine.
Still I have a problem because parking lights are not ON during day so camera stays in Parking Mode. During night time, It's fine.
Hope to hear from other users who installed dashcam using T-Taps.
Old Oct 7, 2019 | 09:44 PM
noclue02's Avatar
Originally Posted by Blade21
Hey guys,
I used spot #4, which is empty spot if I remember correctly. Sorry for the bad picture but the add a fuse is where the red dots are at.
Old Oct 8, 2019 | 11:56 AM
natkhat's Avatar
Thanks - I will give this a try tomorrow.
Old Oct 9, 2019 | 08:55 AM
natkhat's Avatar
Fuse spot #4 is good spot for dashcam. Thanks.
08TLNewbie
Jul 8, 2017 02:32 AM
pstomps
Apr 13, 2016 12:41 PM
PixelHarmony
Jul 26, 2006 04:15 AM
car_lost
Nov 5, 2004 02:16 PM
Brack
Jul 22, 2001 08:36 PM
