Why does the SH-AWD lose mileage versus the FWD?
Is it the functioning of the AWD or is it the weight of the SH-AWD that causes such a dramatic loss of highway MPG? Does 150lb create that much loss of MPG on the highway? Or is it the functioning of the SH-AWD causing tire drag that loses the MPG?
Just curious.
Just curious.
I also agree that I think it is more than weight related and some mechanical linkage is partly the culprit for the deterioration of MPG. I mean 200lbs seems to be the normal weight for most now....does this mean having one person in the car affect the MPG that much?! At 115 lbs, I am not overly worried *lol*
Acura did a good job in reducing the weight penalty, in Canada the Elite SH-AWD is 3785 lbs vs 3631 lbs for the Elite V6.
That's probably the main reason. Still when cruising on a flat highway in warmer conditions (>10C), I've found the SH-AWD to easily beat 31 mpg.
Also, the engine has to use energy to spin the extra driveshaft, gears, etc.
^^ That figure also includes (at least in the US) a slightly heavier (and larger) AGM battery as part of the start-stop system.
Keep in mind the SH-AWD's mileage would be even worse without the start/stop functionality of the engine that the non-SH-AWD's don't have.
I think it is more than just the weight difference. You lose some efficiency transferring power to the rear wheels. A FWD car is generally more efficient than a RWD. Acura uses some tricks to improve fuel economy on the highway.
This engineer does an excellent job of explaining how the SH-AWD works and should explain the difference you see from it as compared to the FWD version
Stew4HD (02-02-2015)
If you're this concerned about the fuel economy you shouldn't be looking at this kind of vehicle. Prius my friend, Prius
Trucks can do this as well as some cars/SUVs; but in general the better AWD systems are always full-time. Part-time AWD systems in cars/SUVs are almost always held in lower regard.
My reason for asking is that I have a new job that is 22 miles from home. If I drive 2 times for 5 days a week, that comes out to 220 miles in a week. If a tankful of gas (I don't care regular vs premium), then I need at least 440 miles of commute (mostly highway, but in Long Island, NY so that is equivalent of city driving for most of US) if I am to avoid filling up more than once every 2 weeks (it's nasty to fill up during polar vortex in winter and heat waves in summer). This is my sole reason for inquiring about the AWD.
Since I live in the suburbs of NYC, snow and freezing rain is likely, thus, I'd prefer the AWD. However, I just fall short of mileage at 419 miles if I multiply the AVG MPG and the Fuel Tank size (24 x 17.2 = 419). The FWD just makes it under at 436 miles per tank...but since most of my driving is highway, I think this will be enough.
For the record, I am the original owner of a 2002 TL-S, but I dont get anywhere enough miles per tank for that car.
PS I also own a Prius, but I dont WANT to drive that car anymore (I used to commute into NYC...). :-)
AWD has
1. More mass to move compared to a FWD or even a RWD car on the same chassis/model
2. More driveline loss from extra rotational losses.
3. there may or may not be different gearing involved. For example my legacy accelerates like any other 4cyl fwd car but it is geared lower to do so. 70mph - 2800rpm on the tach
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Received 2,599 Likes
There a way to turnoff SH-AWD?
You can shut, should, down a true 4X4 system but not many AWD's. They are built for different purposes. AWD is generally a driving aid so you want it there all the time.
True 4X4 is off road, snow, mud traction oriented typically having high & low ranges & are not needed all the time.
I have two 4X4 one with an auto function one without & one AWD. Both the 4X4's have warning labels not to use them in 4WD on dry pavement. This is because the wheels can lockup if they can't slip a little.
The Ranger has 2WD - 4WD high range & 4WD low range. The transfer case is operated from a rotary switch on the dash.
The Expedition has the same functions with the addition of an Automatic position on the switch that enables the 2WD to switch into 4WD high if it detects slippage. Once the slippage is managed it reverts back to 2WD.
BTW Motor Trend has a very nice write-up on the 2016 NSX really like the 4 exhaust finishers #19 on the # 18diffuser, much like the new StingRay
![](http://image.automobilemag.com/f/87326312+w600+q80+re0/by-design-acura-nsx-rear.jpg)
Might it mean that finishers are coming back at mid cycle to the TLX?
To be certain, I would try to get an extended test drive from a dealer and drive your commute to see what kind of mileage you could expect. You'll also need to consider the effect of cold weather, which will noticeably impact fuel consumption.
The commute is really highway---around 60mph for 90% of the trip. I haven't even started at this new job, so I dont know how my TL-S will do in terms of mileage. Usually, I'm lucky if I hit 20MPG in the TL-S (I just love the way the car accelerates...).
joflewbyu2
08-18-2019 10:38 PM
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
