Transmission positive?
I know all the talk about the TLX transmission hard/rough shifts from 1-2 and 2-3.
It was also my ONLY complaint about the car, and was so bad I was contemplating trading it in for german.
Well Im now about 2300 miles into my FWD V6 Advanced and it seems that the shifts have gotten much softer, softer to the point where I can barely feel them compared to day 1. I even had my usual passengers commenting "how come it doesn't jerk when you start off from a dead stop anymore?"
Anyone else have this phenomenon happen? Seems like the transmission smoothed itself out and doesn't Shift roughly anymore unless in sport mode.
The following 3 users liked this post by Juls:
I am only 1300 km (800 miles) in and find the same thing. Part of it is getting used to it and not paying hyper focused attention, part of it is learning to use the throttle appropriately, and i suspect there is also the break in factor. It no longer concerns me and I suspect it will continue to get smoother. Like you, this was my only concern, although not a big one, and i'm happy it is fading into the backdrop. Love the car, love driving it, still gives me a thrill after 40 days. Perhaps its "some kind of a thrill" was a good slogan after all
The following 2 users liked this post by mapleloaf:
a35tl (01-07-2015),
internalaudit (01-12-2015)
I am at 4,600 km and driving today in Normal mode, -15C, the 1-2 shift was hardly noticeable, and there was a very slight bump from 2-3. It was never a problem for me and the 2-3 might have been a bit sharper some time ago in Econ. Driving style may play a part, and I am happy with how it currently performs.
Never had a transmission issue. Still don't. Guess it is because of the South Florida heat? Or just luck?
On my 2.4 with the 8-spd DCT, I'm getting used to the slam when shifting from reverse to drive on a cool morning (35F but 48F in the garage), then the hard shift to 2nd. But today, while almost stopped to await a pedestrian in my path, I received a car-shuddering slam from the transmission. My passengers thought we'd been hit.
I certainly hope there's a fix in the works. If it breaks, no problem. Hit the blue button next to the Homelink buttons, "Hello, Acura? Would you please send a rollback? Oh, and a car? Thanks. Oh and do hurry." We only have to get to 30K miles and thenit's somebody else's problem.
jeremyw (01-13-2015)
CanTex (01-11-2015)
The following 5 users liked this post by SebringSilver:
internalaudit (01-12-2015),
jim256 (01-11-2015),
mapleloaf (01-10-2015),
ostrich (01-11-2015),
weather (01-11-2015)
Mine is "liveable" but not in a league with other $45K cars I've owned.
This may sound hokey to some, but hear me out. I learned years ago that the best ester based pure synthetic transmission fluid made a very noticeable difference in every transmission I put it in...whether a motorcycle or a car. My experience tells me it will also make a difference in my TLX. IF I keep the car past 10K miles, I will be putting the specified Red Line transmission fluid in it along with the
transfer case and diffs' with 100% expectation of improved shifts, performance and decreased transmission noise from each mechanical point. You're going to have to change fluids at some point anyway, so putting a product that is far superior to OEM specs in is worth a try.
I know many of you will be surprised and delighted.
mapleloaf (01-15-2015)
Regarding the 9 speed transmission on the V6, further to my earlier comments I think the more you apply heavy throttle off the line, the more you feel the first two shifts, especially the 2 one. The more you feather it, the less so, regardless of mode. i therefore suspect different driving styles would explain the different views here on the "snap" factor. It is interesting that some say it's buttery smooth and reviewers don't typically mention anything about the issue.
Acura-OC (01-20-2015)
But I finally read one where the tester didn't like the V6 transmission hesitation:
Scott Sturgis/Driver?s Seat: Despite hesitation issues, Acura TLX excels on the road | Pittsburgh Post-Gazette
mapleloaf (01-18-2015)
I drive in Normal most of the time and based on my experimentation I would tend to agree with you. My only qualifier that those of us who drive in normal tend to be less likely to bolt off the line than the Sport or Sport + drivers. This would affect how much you feel those first two shifts.
TLX - V6 Advance
Bought 12/16 - 1600 miles
Mine was shifting really hard 1-2, and especially 2-3. To the point that I was really regretting the purchase.
I took it into service last week, and they weren't at all surprised. They gave me a loaner, kept it a full day, and reset the shift logic, and installed new software that they had to get approval from Acura for.
1-2 is now like silk, and although 2-3 is still noticeable compared to the other shifts, it's light years better. I'm now enjoying the car - couldn't say that before.
Invoice said, " need DPSM 4220 straight time authorization. Reset idle learn and pattern learn - reprogrammed module"
Sorry, that's all they said. And yes, the car already had the ECU / NAV software installed when I got it.
2-3 is still hard in my opinion as mentioned, but much better, and I'm hoping that some miles will smooth it out further.
Also, I noticed no difference before and now in the shift roughness regardless of IDS setting - i.e. normal or sport.
I have an appointment with my dealership in 2 weeks to review the shift issues well documented here. This is with the full involvement of Acura Canada, who I contacted initially. Although no firm commitment has been made officially, I believe there will be a shift logic reprogramming fix in the not to distant future. Although I can live with it as it is, as I usually feather my off the line starts, this car will be even more fun to drive and one to be truly proud of. Fingers crossed!
TLX - V6 Advance
They kept my car for a few days, and had their head tech drive it personally for a few days to test cold morning starts, etc.
I picked the car up late last night, so I haven't had the chance to talk to the manager and fully understand what they did... but the car is (as post above) absolutely silky smooth for 1-2 and 2-3 shifts now!
From what I can try to make out from the repair order- they spent many hours with Acura Tech Line to get this resolved, and wrote the following:
AT-P170A Dog Clutch Abnormal. Updated PCM to ID J4A560. Cleared codes; DO CKP, Learn PGM and Perform Idle Learn Procedure. Vehicle now operating to specification.
So, it looks like new software was installed for the PCM, and the Idle Learn Procedure was done. I hope it stays fixed like this for good. Maybe Acura finally figured it out! : )
The following 9 users liked this post by NJToyMan:
a35tl (01-29-2015),
accord1999 (01-29-2015),
benjaminh (02-01-2015),
mapleloaf (01-29-2015),
quantum7 (01-30-2015),
and 4 others liked this post.
I took my TLX V6 Tech in last week for another issue, and mentioned the rough 1-2 and 2-3 shifts to my Service Advisor and the Service Manager. It was refreshing to see them both nod in agreement and acknowledge that there was an issue.
After updating the PCM and clearing codes, is this all there is to the "Idle Learn"? This is copied from the TQI TSB for the TLX:
10. Do the Idle Learn Procedure
To ensure a steady engine idle, do the idle learn procedure as follows after installing the No. 29 BACKUP (10 A) fuse:
1. Make sure all electrical items (A/C, audio unit, rear window defogger, lights, etc.) are turned off.
2. Start the engine, and let it reach operating temperature (the cooling fans cycle twice).
3. Let the engine idle for 10 minutes with the throttle fully closed.
The idle learn procedure must also be done after updating or replacing the PCM. If does not need to be done after
clearing DTCs.
clearing DTCs.
clearing DTCs.
clearing DTCs.
Maybe they factored in the time they spent on the tech line, or to go out for a cup of coffee while the car idled??
Grandpa
Received 2,609 Likes
While they were playing around with my car, the dealer gave me a V6 TLX Advance to drive for a couple of days.
1860 miles on it and the 2-3 shift was quite noticeable in Normal and Sport. I didn't try Econ or Sport-Plus.
For whatever that's worth.
Thanks to all of you who have posted about your experience with the software upgrade!
Now, apart from making the shift changes smoother, I am wondering if the upgrade did anything to your throttle response at all please?
jeremyw (02-02-2015)
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Mapleloaf,
Can you confirm that 2-3 is as smooth as 1-2?
I'm 2 weeks in after they did my "fix", and 2-3 is still annoying. Under normal acceleration to get to 45 mph from a stop light, 2-3 will still give a jolt in my car.
Brought the car in today. Service manager drove it and confirmed the shift issues. He will write it up and send in to Acura canada tomorrow and then we wait. Their Customer Service folks have been good at follow-up, so hopefully something will happen quickly. In the meantime, as I am usually fairly light-footed at start up, it's not a big deal, especially with all the great features. However, a fix would be very nice! I will keep all posted.
9SpeedTran (02-13-2015),
bbast07 (02-12-2015)
"You are right, the shift that is tough is 2nd to 3rd. Weird thing is my S was smooth when I got it but 4000 km later, it is tough between those 2 gears.Not sure what the problem is with that specific shift.
Yea, I find it weird on how it is usually smooth enough for me, but there are those times, not sure if I'm giving more gas or if I'm driving differently, but it does have a clunky shift there. But I've heard that this is not just Chrysler's, this occurs to Acura's and other manufacturers using this 9speed"
Pulled this from the 2015 Chrysler 200 forum. Interesting, but confirms for me that the degree of acceleration rather than the mode is what determines whether the shift is clunky or not.
After I had mine in the first time, 1-2 which was almost as bad as 2-3 became like butter. 2-3 was better - at least at slow speeds it was perfect.
Now the bump is there and annoying, especially at about a 20% throttle acceleration from stop (say to get to 45 or 50 mph) from a dead stop - 2-3 will really lurch.
Having done copious amounts of reading (as I know everyone has), I'm convinced it has to do with the dog clutch on that shift not matching revs.
I sent an email to the service mgr at my dealer (which has been great btw), to see what's going on with software updates.
Keep you all posted.
mapleloaf (02-13-2015)
I own the 2015 V6 FWD and am having the same transmission issues as those here (annoyingly harsh upshifts between 1-2 and 2-3). I called my service advisor to schedule a repair and received this voice message:
"Acura is working on a software update that is supposed to fix that [transmission issue], among a few other things on the car. I won't have that software download available until the end of March. Acura plans to send out a notice to owners of all affected vehicles."
So while some of you have had luck getting a repair, it appears that a more robust fix is on its way. Apart from that issue (not trivial), the car has been great.
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
