From Running to Acc?
Is there a way to turn off the car without turning the power completely off? This is the first push-button-start car that I have owned. In my previous car (3G TL), if I was on a phone call and I reached my destination, I could turn the car off, but only to ACC, and still maintain the phone call. Now, with the TLX, I have to either leave the car running while I'm parked, or transfer the phone call to the phone. Any way around this? I would like to be able to maintain the hands-free connection once I turn the car off.
this would be true on the 4 cylinder (and is true on all the previous Acuras with keyless start), but on the V6 TLX with the push button gear selector, the car will automatically go into Park and then shut off the car. The only way around this I can think of is to use the "car wash mode" by pressing N for neutral and then press the engine start/stop button within 5 seconds. This will go from run to acc, but keep in mind the car will be in NEUTRAL so you will want to make sure the parking brake is set. The car will stay in acc mode for 15 minutes and then shut off and put the car back into park.
BookemDanole (11-07-2014)
A few years back I noticed that in the Infiniti G35/G37 you could achieve this (running to directly acc) by double tapping/pressing the start button. I have tried that in my TL and it doesn't work - wondering if that works in your TLX by any chance.
My CLK with "keyless Go" goes into ACC after one tapping and shuts off when the driver side door is open to exit.
TLX, I always put in in Park and tapping the start button by habit...Them it shuts off.. kinda annoying especially when you are talking to on the phone..
Well time to re-train my muscles i guess ^^
If you have a 4 cylinder, with the car in park and still running, try holding the gear shift selector button in and press the start/stop button at the same time..works in my MDX and my wife's RDX..not sure if the same with the V6 TLX with the push button transmission. Otherwise should be in your manual somewhere.
Once stopped, try shifting from Drive to, and staying, on Neutral. Then push the Start button once, which should shut the motor off, leaving the car in Acc mode.
Works in my Infiniti M. I'll try it later in my wife's '15 RDX.
clk350 (11-08-2014)
Thanks, but when I do that the car automatically shifts to park and shuts off.
Seems there should be a better way without leaving the car in neutral.
I would see the opportunity for rolling issues since you may become distracted while on the phone.
There should be a better way.
Seems like doing a transfer is the safest option, besides leaving the car running and wasting gas.
Maybe they will put it in the next software update?
For my I4 TLX, as suggested, put it in to N, parking brake on and then press start/stop button to get into ACC mode. you will get a warning "shift to P".
After done with a phone call, put it in to P to shuts it off completely or restart.
It works pretty well for me.
xiaosongz (11-10-2014)
Yeah, but my whole point is that when the car is shut off completely, the phone call hangs up as well. I would like to be able to shut off the car and have it go straight to ACC; similar to what you can do with a traditional key ignition.
I thought about that, but someone mentioned that they wanted to keep their bluetooth call going. That would cause a drop of connection.
I guess that is worth a try on my next test.
So close, yet so far
I found that before I turned off the TLX, I put it in Park, kept my foot on the brake and held back on the gear shifter knob button. I then hit the power off button. It went into Acc mode. It actually said it on the OMD. The power remained on as long as I held the gear shifter knob button. Once I left go, the car shut off. I was so close. While in this weird Acc mode, the power light LED is flashing green.
I did try once more and before I let go of the gear shifter knob button, I pressed the start button again, once the engine stopped. This time it switched to ON or Acc-2. It stayed in the on position, not the Accessory position when I let go of the button.
Maybe there is a key sequence I missed.
I know it is not acceptable for the I4 and not even a chance on the V6 but maybe it gives us a hope to search further on both.
My RLX does this, too. Frustrating. Luckily, in my hybrid, the engine shuts off if I keep the car on, so I'm not wasting gas. The only solution for you guys with the push button trans control is the car wash mode, which also works in my RLX.
Acura needs to issue a STAT software patch for this issue for both cars.
tlxsteve (11-09-2014)
I think I might have stumbled into a way to do this...
Coming from a 4g 6mt, I am used to parking, hitting start/stop button, then putting on the emergency brake.
If you hit the start stop button without the car in park, it will put the car in park and turn to accessory mode....
At least it did for me last night in my v6 TLX.
Can you verify your findings?
I am surprised about this. On my 2010 TL-w/Tech, if I am on a phone call and I turn off the car, it does not drop the call. The call stays on the hands-free speaker until I hang up even though the engine is off.
My 2008 TL w/Navi does the same thing. It won't drop the hands free call when I shut off the car.
If I hit the start/stop button while in Drive and stopped- the car is placed into Park, but turns off completely (and not in Accessory mode). My call is dropped.
tlxsteve (11-10-2014)
I can confirm that on MY car (2015 TLX sh-awd Elite), if I hit the start/stop button while I am stopped with my foot on the brake and in drive, the transmission is placed in Park, and the car is in accessory mode as shown on the MID.
Oh and I can think of one other thing that might be skewing my results: idle stop was on, and the car "turned off" before I ran the test. I got it to turn on by adjusting the pressure on the brake pedal while still keeping the car stopped. Then I did the above.
I was asked if I could confirm what I had done accidentally a couple of times, and I did that.
I am sorry it doesn't work for you.
Ok, let me be more precise.
Guess we need a chart with the various options set with a type of vehicle listed. So far I have only seen one person get this to work. Crazy.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
