Remote start questions, please?
I just got my new TLX Advance and have a few questions about the remote start and I welcome your help.
Trying it for the first time last night in the dark and cold northeast USA, upon climbing into my TLX after using the remote start, I noticed the following as stated in the Owner's Manual:
".....the security system remains on, and lights and accessories remain off."
I assume this is to allow the car to keep a low profile in a public lot while parked, but once I get inside the car, how do I turn on the dash lights and everything else? I unlocked and got in the car, while the engine was running but everything was dark; the dash lights and all displays and outside lights were all off.
How do I turn all the lights back on? I had no choice but to shut the car off and re-start it again. Is there another way to light everything back up?
Thanks in advance for your help!
As soon as you enter the car and are in the driver's seat, place and hold your foot on the brake pedal and press the "Engine START/STOP" button on the dash.
The car will go to "on" mode; all lights will come on, and you can then put the car into gear and drive away without having to shut the engine off or restart.
First of all, CONGRATS on getting your car!
I have used the remote start a few times, including this morning.
If you get into the car while it's still running, the MID should display 2 different notices. One is if you want to put the car into ACC more, then push the Start button.
If you want to keep it running, then push the brake and start button. When I do this, everything lights up as per normal. I have the lights in Auto, by the way
Hi Pmartone.
I just put my food on the brake and hit the start button. The lights turn on and engine keeps running. Then I just drive away. Does that not do it for you?
(this is a great improvement over my RDX, where the engine automatically stops when you open the door)
This is the first Honda/Acura I know of where when remote started it does not automatically kill the engine when you enter the car...finally - it is the major reason people choose after market remotes. That just leaves the range issue (again the TLX is far better than other Honda remotes range wise, but most after market are still a lot better. And the auto killing of the heated steering wheel and seats...they'll get it right eventually.
Walking out of my Hospital building, it reaches the span of the entrance, across 6 lanes of traffic, and starts my car which is sometimes parked against the farmost wall of a concrete parking garage on the 3rd or 4th floor.
The best part is just looking at the remote, and getting the green light to let you know that it did indeed start your car that you can't even see. (The same applies to the doors if you are unsure you locked it. Hit the button on the remote, wait for the green light, and you are all set.)
Absolutely love the built-in remote start feature! It was a hassle to keep another remote whether it's an Acura-installed (on my MDX) or aftermarket starter (on my other old cars).
Stew4HD (12-31-2014)
I just picked up my new TLX on Friday. Traded in my 2008 Accord. Love the car so far and will have to spend a few hours or maybe days trying to figure out how everything works. We are having a problem with the remote start though and maybe someone can help and save me a trip back to the dealer in the morning.We have tried to use the remote start many times and only twice have been successful at starting it. After hitting the lock and then the engine button it starts to turn the engine over for one second but stops immediately and the red light blinks on the fob. This happens with both keys. Any suggestions??
Bruce, after I hit the lock button the green light blinks and then I press and hold the engine button and the yellow led blinks a few times and then the red led comes on. Sometimes it tries to start it other times nothing at all happens. I just went and tried it again and it started this time. Turned it off and waited a few minutes and tried again, nothing.
Odd. The middle green tells you the car is started. today I was about 75 yards from my car, with a building in between and I was able to start my car by pointing the fob straight ahead, not through the building. Amazing!!!
Remote start problem solved. My battery died a few days later. As it turned out it sat in the railyard for a week or so before it was delivered to the dealer and froze solid a few times. The battery was probably weak when it arrived. Was not strong enough for the remote start to work. they promptly replaced it.
Bruce Dow (01-18-2015)
Lol. I can start my car from my 9th floor office and my car is on the 3rd floor of the parking garage next door. Of course I can still see it, but still... makes it nice when it's cold outside and I can start the car from the office and by the time I get there a few minutes later, the car is warming up. I can also lock the car from a covered walkway on the ground floor while the car is on the 3rd floor (not in the line of sight) and can hear it beeping as it locks.
Everyone is right, press the lock button twice, to make sure it's locked, and then press start and the Amber lights flash on the remote, then the green light flash, car is started and when you walk up to it, press unlock or put your hand on the handle and the car unlocks, get in press the ignition button with the foot on your brake, ready to roll!
Another remote start question for those living in a cold Canadian climate. I find the ten minute running time no where near heats up my car. The temperature gage has not even budged when I get in it. My old Maxima was always warm and toasty by then. Is it that it is so efficient now it just does not warm up as fast and I will just have to extend it the 20 minute running time if I expect a warm interior? Btw the steering comes on but never the seats.
We recently had -25C weather and it works fine.
I do wish the front window defrost would not start all the time as I do not need it. Hoping in warmer weather it does not come on.
Just a gentle reminder that excessive idling is not particularly good for a car, or the environment. a few minutes is all I ever use and all the car needs. I don't use it in the morning as I garage the car and although we have typical nighttime winter temps of -20+ Celsius, this engine and car warm up very quickly. Love it!
If you allow the car to turn itself off after the first 10 minute cycle, you cannot remote start it again until you physically go to the car, open the door, and press the engine start-stop button.
If you try another "remote" start after a ten minute warm up- the remote FOB just blinks red, and the car cannot be started.
This isn't really explained in the owner's manual, but this is the way my V6 Tech seems to work (I had the Acura Remote Start added with my $500 allowance credit).
Not sure if Advanced/Elite operates differently, or others experience what I do.
Checked temp
I checked the temp gauge after letting it warm up from the remote start. The gauge was at the bottom but as soon as I started the car by pressing the start button in the car the gauge did go up.
About the fob timeout. I read somewhere and it works as i tried it this evening. Remote fob start. Ran for 10 minutes. Let sit off for 10 minutes. Remote fob start again. Basically have to leave it for 10 minutes to use fob again.
Acura TLX 2.4 Tech 9-2014
Anyone have this issue, when I go to remote start my car (I added remote start by Acura to my 2.4 Tech TLX) the orange lights blink a few times then the red light blinks and nothing happens (normally the green light blinks indicating success).
Have not done anything differently since it was working before, any tricks?
B.
B.
B.
B.
B.
B.
It has fixed things for me before.
B.
B.
You may also just be out of range.
Thanks for the suggestions, BTW if you need to turn off the car remotely after starting it you can shut it off with the remote key fob as well, in case anyone was curious.
B.
rockyboy
08-04-2024 10:35 AM
