Modes
Old Aug 30, 2018 | 08:30 AM
zmetman's Avatar
Modes
Does anyone use the economy mode or Sport Plus mode with any regularity? The only modes that seem to be drivable for any length of time are the regular and sport mode. Does anyone know if the Sport Plus mode has been retuned in the 2019 aspec?
Old Aug 30, 2018 | 02:52 PM
CheeseyPoofs McNut's Avatar
I love the steering feel in sport plus but it's not usable for any length of time. I leave it in normal mode 95% of the time and never think about it.
Old Aug 30, 2018 | 03:57 PM
BEAR-AvHistory's Avatar
Different make but I use Sport+ for all but high speed interstate which gets comfort mode for top gear access & gas mileage
Old Aug 30, 2018 | 07:37 PM
Saintor's Avatar
Yeah that is what a ZF transmission does to you. Same here.
Old Aug 31, 2018 | 07:39 AM
zmetman's Avatar
I find Sport Plus mode way to balky
Old Aug 31, 2018 | 04:15 PM
hdcolumbus's Avatar
Super Car Enthusiast
Sports+ 100% of the time. I couldn't go back to any other mode. (2019 A-spec)
Old Aug 31, 2018 | 05:38 PM
F23A4's Avatar
Sport mode just about all time; have only found myself in Eco mode by accident (wife maybe use the car and left it in that mode) and use Sport+ mode when I really want to wind it out, which is very rare.
Old Aug 31, 2018 | 09:59 PM
a35tl's Avatar
'16 TLX Advance. Sport mode 99.9% of the time.
Old Sep 2, 2018 | 07:09 AM
wlkeel's Avatar
Sport mode unless I'm in the mountains and want to manually shift, then Sport+
Old Sep 2, 2018 | 11:38 AM
Can't you use the paddles in all modes?
Old Sep 2, 2018 | 01:38 PM
CPR's Avatar
CPR
SPORT 99% of the time
I've found when you live in the city, this works best
upstate, in the mountains, SPORT+ is tons of fun
Old Sep 2, 2018 | 06:20 PM
wlkeel's Avatar
Yes, but it won't stay in manual mode if you drive a short distance at steady throttle - it reverts to the mode you were in before and stays in drive (not manual). Sport+ stays in manual.
Probably didn't explain it well, but that's my story and I'm sticking to it
Old Sep 2, 2018 | 07:10 PM
That's normal. Not really an issue because the paddles are always alive so anytime you pull one it functions. You don't lose any performance.
Old Sep 4, 2018 | 09:53 AM
Speed_Racer's Avatar
6 Forward 1 Back
Well, you do because of how Sport is programmed. I see it a lot on clover leafs with freeway interchanges. In Sport as I enter the cloverleaf I'll drop it down a gear or two, mid way through it goes back to D and i have to downshift again as I merge onto the next freeway. In Sport +, i can downshift as I enter the cloverleaf and it keeps it in gear through the merge.
Old Sep 4, 2018 | 02:18 PM
Does it lose the lower gear under load when it shifts back to D? Mine will hold the gear till I unload the throttle or the RPMs hit a shift point where I would normally upshift if in full manual.
Old Sep 4, 2018 | 05:08 PM
6 Forward 1 Back
Unfortunately yes. I want to say it goes up a gear or two, but for sure it doesn't keep it in the same powerband because the RPM's will drop when it goes back to D. I'm always then paddle shifting down to get the power back up. Shows the difference between Acura and BMW programming on their transmissions.
timbrwolf9
Oct 19, 2004 09:05 AM
Zerostatic
Apr 15, 2002 10:28 AM
eman
Aug 1, 2001 10:51 AM
