CAM Chain Tensioner TSB (2.4L), First At My Local Dealership
Old 07-03-2019, 09:56 AM
5th Gear
EngineeringInStyle's Avatar
Just wanted to start this thread to warn people of what this issue sounds like and about how much it costs to fix out-of-warranty since my local dealership told me I am the first to actually have the issue of the 2.4L TLX's they service.
So, some background on this is I got this car in February from a non-Acura dealer with about 75k miles, and all was well at first. About a month later I started hearing what was almost a rattle in the startup noise, definitely not just the clean start up grumble you usually hear, it was very obvious. In addition to this an audible clicking could be heard coming from the engine until it warmed up. So, being the paranoid car-freak I am I searched to see if anyone had this issue and came upon the TSB. Sure enough, upon taking my car to the local dealer and leaving it overnight so they could hear it cold start next morning, they heard the noises and then upon inspection confirmed there was wear on my CAM chain tensioner check valve. Of course being out-of-warranty I had to pay out-of-pocket, but thankfully the service was only $183.88 before tax, so definitely annoying but not ludicrous.
Basically, if you are approaching your end of warranty and hear anything out of the ordinary during cold startup or clicking from the 2.4L engine go get it checked out! There is a revised version of the part that should hopefully not have the same issue that is installed as part of the service - time will tell if they actually fixed the design flaw that caused the problem.
Also, just for reference and as further warning with buying the TLX used, my transmission software was also still on the original version and as such had the bumping when stopping quickly and the slow shifts / feeling of slipping when cold. An update and burn-in of the clutches fixed this issue immediately, the dealer charged $36 for the service so it was well worth worth it to have a much smoother transmission.
9SpeedTran (07-03-2019)
Old 01-03-2021, 09:07 PM
Raver27's Avatar
Hi,how long did rattling noise last upon startup?My 2018 tlx has this knocking/rattling noise during cold start up that last about 2 or 3 seconds, doent always do it,but thought about it after coming across ur post.
Old 09-28-2021, 06:25 AM
4th Gear
Carl Theriault's Avatar
I have the same problem whit m'y tlx 2015 2.4
sound bad 2.3 sec Start .
Old 09-28-2021, 08:52 AM
NDNV's Avatar
Here is a copy of the TSB. Applies to 2015-2018 TLX with 4 cyl. Knocking or Clicking From Engine During Cold Startup (urvi.net)
Carl Theriault (09-28-2021)
Old 09-28-2021, 09:07 AM
4th Gear
Acura tlx 2015
Tanks are you From Canada or United States ?
Old 09-28-2021, 02:21 PM
NDNV's Avatar
Old 09-28-2021, 02:29 PM
4th Gear
Tlx 2.4
Perfect tanks m'y Acura dont have a bulletin service im located Montréal can you give me a name of your Acura dealer please ?
Old 09-29-2021, 09:38 AM
NDNV's Avatar
Not necessary as I just pulled this TSB link from the web. No personal experience with this issue. Just print it out or tell them to check TSB #19-012.
Old 09-29-2021, 09:43 AM
4th Gear
Ok tanks you !!!
Beaverking
6G TLX (2021+)
251
02-01-2021 08:07 AM
Layton1
3G RLX (2013+)
41
10-22-2019 09:31 PM
mrjohn90
2G TSX Problems & Fixes
10-29-2013 06:20 PM
hyunh311
03-22-2013 08:07 AM
KJ32
02-27-2003 03:52 PM
Quick Reply: CAM Chain Tensioner TSB (2.4L), First At My Local Dealership
