Auto Idle Stop
Vancouver Island BC
Auto Idle Stop
I have a v6 advanced (elite in Canada). The auto idle stop worked for the first week. It now doesn't come on even when pressing brake firmly. I can dis in-gauge by pressing on button by brake hold, but can't find out how to re in-gauge or what I might have done to shut it off.
TNTransplant (01-05-2015)
I have the similar issue, however sometimes it will work and other times I get a message stating that it is unavailable. I thought that it could have possibly been because i was using too many other auxillary things (wipers, heated seats, nav, radio, etc.), but even after I turned off most of them, the idle stop still would not work. I plan to visit the dealership shortly to see what the issue is.
Forum Contributor
Received 1,392 Likes
See the following technical training video for details:
ECC07-Non-Hybrid Idle Stop
https://acurazine.com/forums/fifth-g...videos-915166/
Thanks for posting this response which leads to the technical training videos. I had ignored the training videos previously. After viewing this video I am now going watch all the other training videos also. I like to know how things work and this training video provided a lot of information.
There are numerous factors that determine whether Idle Stop is available. Battery status, humidity, defrost operation, etc. I noticed in particular when it warmed up here a few weeks ago and was above freezing, the humidity and prevented the system from being available. Excessive cold drains the battery more, so again, bot typically available. 10 below C or so, it generally is available.
Sport + disables the idle start/stop system; Sport does not.
It also won't engage under certain conditions such as an engine that hasn't warmed up yet; if its excessively cold, or humid; etc..
There are prompts available in the computer system for the start/stop which will flash info in your dash such as the system is "unavailable" when the computer determines not to shut the engine, or if you are stopped with the engine off, and it needs to refire prior to taking your foot off the brake. You just need to turn them off, and on.
Stew4HD (01-05-2015)
One interesting tidbit I picked up from the technical video: the system monitors the number of start-stop cycles and, once a predetermined number of cycles have occurred, suspends the start-stop feature and informs the driver to... replace the starter.
This answers one of my concerns re: accelerated starter wear!
Acura needs to get with the competition. My A6 there is a single button I press and it remember the previous state on whether to engage start/atop or not. I really want o come back to Acura, but they keep doing annoying things.
At some point you have to wonder if the Feds will force them to leave it enabled at every start or always, after all I am sure the MPG sticker reflects using start/stop and maybe at some point the feds will consider bypassing it gaming the numbers.
Should be an easy firmware fix. I am hoping the SH-AWD will become more available in Atlanta and may consider one. There are still some annoying things about the dual screens that turn me off, but I am sure I can get past them. It would suck to have to remember to disable start/stop every day.
The dual screens are actually pretty nice once you learn them. I like that I can keep the nav up and have the second screen to do everything else.
I'd bet that's already happened.
Talk to any Corvette owner about anything features to bump up the mpg stats. Skip shift anyone?
Personally for me, I've become fairly good at modulating the brake pedal to use the system as I want.
Here is the response from ACR regarding my email complaint about not being able to disable the feature and have it stay off:
I will get used to either just pushing the button, turning the steering wheel slightly at a stop or using the brake lightly.
Your valuable comments pertaining to the operation of the Auto Idle Stop feature are documented in the reference file below. Our design and engineering teams have access to this file for review. We have confirmed there are currently no campaigns (safety recall or product update) regarding the Auto Idle Stop feature. You have the option of disabling the system using the on/off switch which we have confirmed resets with ignition cycle.
I guess because I also own an Altima 2014 and occasionally spend time on that forum, that I appreciate my car more than some. It perhaps gives me some perspective. I have never looked forward to driving a vehicle as much as I do my 3.5 TLX SH-AWD Tech.
They can't advertise mpgs using a system like start/stop which can be turned off, and left off.
I'm sorry but the fact that you "need" to press a button on the electronic shifter to disable Idle Stop doesn't seem to me like a deal breaker. I prefer to have it on unless I disengage it. In stop and go traffic or drive-thrus, saving some gas is not a bad thing. and if you don't like it, take that precious 1 second to PUSH THE BUTTON. if that is keeping you from coming back to Acura, me thinks you won't be coming back.
I know some of us are picky, it is like the damn OK nag screen every time you turn the car on, why does Acura do it, my Infiniti and Audi never do it. Why have to hit a start/stop disengage every time, etc. All those minor annoyances add up and at some point they become deal breakers for people.
It would nice if at least Acura made it a "learned" feature...in other words, when you de-activate the start/stop button, it would remember it. Almost like a switch than remains engaged....when pushed in, it would activate the start/stop and when the button is not depressed, the start/stop feature would be off.
They could calculate the city fuel ratings with the start/stop feature and have that listed in their mile long disclaimers (lol)
My 2 cents....
My 2 cents....
Stew4HD (01-07-2015)
More learned features would be nice. Perhaps the best and cheapest solution would be to add Brake hold and Idle Stop to the Preferences in the Heads Up Menu, much as BSW for example. You could also add Heated Seats with start up to the same menu. This works nicely for IDS choices as well.
I suspect folks would pay a little more for those choices. However, I am a button guy, so the current options work fine for me. I have my quick airline pilot checklist after starting up the car
We are in the digital era and accustomed to customization all our electronic devices, and the automotive industry is playing catchup.
Examples of "states" they have got right (not just with this car) between turning the car off/on:
- Cruise/Main (remembers last setting)
- Climate Control (remembers last setting)
- Rear Window Defogger (always off when car started)
"States" that need to be tweaked
- Idle/stop (needs to remember last setting)
- Brake Hold (needs to remember last setting)
- Heated Windshield (do not turn it on automatically in cold weather, but this is likely done for those drivers who do not know about the feature or where to find the switch)
So drove 63 km in the city and during the day today in my 3.5 SH-AWD. Temperature was -18 C and very blustery. The longest errand stretch was about 18k and with the Idle stop kicking in at most lights and a fair bit of continuous driving without stops, I average 9.0 l/100 km (31 mpg Canada, 25 mpg US. That was pretty impressive, especially as i have just over 1300k on the car. Perhaps the Idle Stop helped
9SpeedTran (01-18-2015)
The following 2 users liked this post by ostrich:
9SpeedTran (01-18-2015),
Bruce Dow (01-18-2015)
Just curious (since I have a 4 cylinder TLX), but does anyone with a hybrid have a comparison of the restart of the engine from a vehicle stop on the TLX V6 to the restart on a hybrid? I have a '13 Lexus ES 300h, as well, and most times when you accelerate from a stop the engine will start. There I'm getting motor generator power as well, and the car moves off but will give a slight tug or rumble as the engine (2.5L 4 cyl) starts. Nothing annoying, but part of the process once you understand all the hybrid's 2 generators, engine, and CVT are doing. It's my third hybrid, so I'm used to all that is going on, but I would be interested in comments from someone who has the V6 TLX since I may be looking at a Honda/Acura product with the V6 later this year. I think Toyota has done a great job of making it a good drivetrain, and have found on the Lexus boards that people who over think "how do I drive a hybrid?" tend to have more issues. BTW, after 2 years, 41 mpg on regular gas on the 300h.
I also find that it's generally quite easy to avoid engaging the idle stop by feathering the brake when stopping (i usually drive so that I don;t need to do much sudden braking)…assuming that is that you forgot to turn it off if so inclined. After experience I would say it's only engages about 50% of the time depending upon weather and other electrical functions are working significantly and draining battery power.
The following 2 users liked this post by mapleloaf:
You can't compare a hybrid and non-hybrid. The non-hybrid uses a "regular" starter which uses a solenoid to engage, start the engine and then disengage. Hybrids use an electric motor mounted in series with the engine (honda technology) or in parallel (toyota technology) that doubles-up as an engine starter. Therefore, hybrid re-starts or starts are smooth and almost imperceptible.
What I am getting at is that when it doesn't downshift like expected, the car will jump into first when accelerating from the near stop causing the same lurch forward as the car does when the engine stops and starts while you've pushed the pedal down. I hope I have explained this well enough.
IMO, they need a software fix for this as well as the "stay off" Idle stop.
Have you noticed that when you do the "feathering" of the brake at a stop that the car doesn't always downshift into 1st? The system doesn't seem to like "California Stops". Also, it seems the car needs to come to a full stop for a period of time (1-3 seconds?) before it drops to 1st.
I will start by saying that I like the idle stop. But I realize that there are some situations where I don't want it to engage. (Like when I know that the stop will be very brief.) Feathering the brake is key, but takes some practice. There is a "sweet spot" where you CAN engage the Brake Hold, but NOT engage the Idle Stop.
DerrickW
11-15-2015 05:52 PM
spoiler900
10-10-2015 06:48 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
