Adding driving lights to 2020 TLX
Good day,
Already did forum search. Tech package car without driving lights. How difficult expensive would this be to add? Can there be separate rocker switch added to lower left switch cluster or would I need to change the turn signal stalk/switch?
Thanks,
Mike
Thanks,
Mike
I'd recommend taking a look at the fog light installation instructions here to get an idea of how involved it may be.
The question you should be asking yourself is, do you really need "driving lights"? Usually extra lights are added if you're off-roading at night, or frequently driving in super dark and low visibility situations where extra light is needed for safety purposes. Or, do you want to just look cool?
Otherwise, it's probably not worth the time and cost to add anything beyond OEM lighting, which are perfectly good DRLs and low/high beams.
Joe Foe from Buffalo
Jul 18, 2021 12:12 AM
