Wheels spec confirm
Old May 4, 2012 | 05:24 PM
Recall's Avatar
Wheels spec confirm
I got the wheel specs for the HB 29 wheels they will be 20 x 9J offset for the front will be +25 medium concave.
The rear will be 20 x 9J offset +20 deep concave on 245/35 Hankook tires.
The car has been lowered now on H & R springs.
Will this set up cause any problems? please to voice your opinion or thoughts.
Thanks,
Regards
Old May 4, 2012 | 05:33 PM
potmilkz's Avatar
it should be fine with a little fender roll and a good camber kit
Old May 4, 2012 | 05:41 PM
KarKraze's Avatar
I think that you will def.need to roll your fenders.
Old May 4, 2012 | 06:04 PM
Recall's Avatar
Oh no! I don't want to roll the fenders.
Old May 4, 2012 | 07:06 PM
Edward'TLS's Avatar
6G TLX-S
Then ask HB for some higher offset wheels. There is no way around it if the tires/wheels are sticking out of the fenders.
Old May 4, 2012 | 08:02 PM
Recall's Avatar
You guys are simply the best I have inform them to come up with a higher offset and when they do so confirm with me, so lets see what they comes up with.
Thanks again guys.
Old May 4, 2012 | 09:01 PM
njsimons's Avatar
Anything less than +35 you might end up rubbing.
Old May 5, 2012 | 06:18 AM
FYAH TL's Avatar
Chapter Leader (Northeast Florida)
Like njsimons said anything less than +35 you might end up rubbing. So get wheel offsets of +35 or higher for those 20x9 wheels. Then you don't have to worry about fender rolling.
Old May 15, 2012 | 11:58 AM
djtanveer's Avatar
I am running a +30 offset for my front. I rub when going up driveways and turning at the same time. I would recommend going a little higher offset.
for your rear you will have a really hard time running a +20 offset and having 245 on a 20x9. I stretched 245/35 tires on 20x10 and i had to cut my rear fender lip to get the clearance i needed.
Old May 15, 2012 | 12:18 PM
Treblig's Avatar
Just to be sure, +35 on a 20x9 wheels with properly sized tires (non-stretched) will not cause fender rubbing? Does that place the wheel flush with the fenders?
Old May 15, 2012 | 12:25 PM
Zelaya's Avatar
2012 TL SH-AWD
I'm in same situation, can someone confirm if safe to get 19x9 for square setup or 19x8.5. The offset is something I'm not too sure about but the worse cases no more than 40 offset.
Old May 15, 2012 | 06:52 PM
Recall's Avatar
To be on the safe side I decided to go with 20x9 offset +40 all around with 245/35. I am just waiting now for the wheels to come.
Old May 17, 2012 | 10:04 AM
FYAH TL's Avatar
Without lowering the car it will be very close to flush hence you'll be riding 4x4. But when you lower the car if you plan to then +35 will have the wheels sit inside the fender. Note:The more one lower the car suspension the more the wheels tends to sink inward.
Old May 18, 2012 | 02:55 PM
ANDYCHULOSKI09's Avatar
My new set up is going to be 20x10.5 + 27 offset at all for corners..... really STRECHING my limits here guys
Old May 18, 2012 | 09:11 PM
Edward'TLS's Avatar
6G TLX-S
Keep us informed of how it goes after putting on the new setup.
Old Jul 4, 2012 | 09:33 PM
Recall's Avatar
BC Forged HB29 Wheels are ready now
Hi Guys, the wheels are ready, shipped and install. 20X9 et40, it looks good, let me know what you guys thinks. I think a little more poke would have been perfect.
Thanks.
Old Jul 4, 2012 | 09:55 PM
Zelaya's Avatar
2012 TL SH-AWD
Looks nice. Can you post side pics
Old Jul 5, 2012 | 11:49 AM
RPhilMan1's Avatar
2024 Honda Civic Type R
Wow! Those look fantastic!
Old Jul 5, 2012 | 01:06 PM
ucf_bronco's Avatar
Love it! Need to see more pics though!
Old Jul 5, 2012 | 03:20 PM
potmilkz's Avatar
those are the same wheels this other member has.. he has a blue 4g tl as well..
you need a drop tho.
Old Jul 5, 2012 | 05:30 PM
purextc's Avatar
Wow! that looks awesome!
Old Jul 5, 2012 | 06:25 PM
Recall's Avatar
Yes, it is lowered on H&R springs, I will post some more pictures with the car sitting on a level ground, they are the same wheels as Djtanveer, I saw them on his car and he gave me the info to get them.
Old Jul 5, 2012 | 08:38 PM
KarKraze's Avatar
Looks really sharp,def in for more pics,i hope to see your car in person one day.
Old Jul 5, 2012 | 09:02 PM
FYAH TL's Avatar
Great progress and looks good Recall. Love how those wheels being that color pops nicely on that black exterior paint. Concur you could have gone a little lower on the offset for more poke, if it bothers you for not being flush enough to your liking running spacers can help to fill the gap...You should start a thread in the photograph galley section with pictures from different angles.
Old Jul 6, 2012 | 05:10 AM
djtanveer's Avatar
wow. those wheels look familiar they look good. I see you went with different center caps than mine. congrats on the wheels.
BTW: isnt it cool how the inner barrel is painted black and not left with an unfinished look?
Old Jul 6, 2012 | 10:17 AM
Zelaya's Avatar
2012 TL SH-AWD
Looks sick op, what's the price tag?
Old Jul 6, 2012 | 10:26 AM
eazy's Avatar
WDP 4G
You went from bit aggressive to a bit passive on the offsets. 35 front and 30 rear should give you the look you want. so a 5mm and 10mm spacer should fix ya up. Other than that looks good
Old Jul 6, 2012 | 10:30 AM
eazy's Avatar
WDP 4G
I'm running 19x8.5 42 offset squared and I'm pretty much slammed. I don't have any issues really except the rear when I go over a hard bump the rear tire rubs slightly against the rear bumper tab. I'm gonna get the tab shaved down but if you're not as low as I am there will be no issues. I'm actually considering selling these SSR's with the tires.. If you're interested we can work something out
Old Jul 6, 2012 | 11:05 AM
i64X's Avatar
Those looks REALLY good. I wasn't sure when I saw just the wheels sitting there by themselves, but on the car they look awesome.
Just out of curiosity I would like to see +10 more poke on the back and +5 on the front. At least this way you won't have to worry about rock chips on your rear fenders though.
I'm curious about the the price. Also can't wait to see side shots.
Old Aug 6, 2012 | 02:14 PM
KarKraze's Avatar
Having seen this car i have to say that those rims are outstanding,when the car is rolling it has a beautiful presence,stance is perfect with the H&R as well.
Job well done and many thanks for the info.
Old Aug 7, 2012 | 04:31 PM
Recall's Avatar
It was certainly a pleasure to provide you with all the info. Thanks for the compliments, your TL is superb,unique, also in a pristine class. Thanks for the drive the sound is awsome too.
Regards
Old Aug 7, 2012 | 04:49 PM
Big mo's Avatar
Big Mo
What PSI do you have your tires at?
Old Aug 8, 2012 | 11:11 AM
Recall's Avatar
32psi all 4s
yvr_tsx
Sep 15, 2015 01:14 PM
DunesCreations
Sep 9, 2015 12:03 PM
nuldabz
Sep 3, 2015 05:49 PM
