Vibration after lowering and new wheels
Old Sep 14, 2014 | 10:00 PM
TLCEEZ's Avatar
Angry Vibration after lowering and new wheels
So frustrated...so lowered my car yesterday on Tein S-Tech springs and got my new wheels on. Drove around for a bit and everything seemed fine till I got on the highway and got to around 60mph..then the vibration started. I initially thought maybe the tire shop hadn't done a very good balancing so this morning I took it to another shop to have re-balanced. Drove off and everything seemed fine for a bit until again I got on the highway and the vibrations returned.
Lugs are tight and everything looks right. (checked to make sure I didn't leave a bolt or nut loose from lowering it)
So tomorrow I am putting the stock wheels back on and seeing if the vibration is still there...if so, then it should be something with the car and not the new wheels right?
The vibration is very strong on steering wheel and I can kind of feel it on the brake pedal when I brake. Could it be the rotors? I did use a pry bar when taking out the shock. Could I have bent one?
Idk. Not really sure what else to look for. Any suggestions or advice is appreciated.
-c
Old Sep 14, 2014 | 10:40 PM
andrewcjduong's Avatar
Test out the OEM wheels first and see, if not. Check your rotors and pads. Also, have you done an alignment yet? Your car may be unaligned so that could solve your issue.
Old Sep 15, 2014 | 11:44 AM
lift3d_'s Avatar
rock the block
get an alignment, make sure toe is 0
if that doesn't help, get road-force balancing done on each wheel. I believe Hunter is the manufacturer of the machine, go on their website and find a local shop that has one.
enjoy!
Old Sep 15, 2014 | 11:45 AM
TLCEEZ's Avatar
No alignment done yet. Honestly, never have done one in any of my cars after lowering them. Could alignment really make it vibrate like it is? Sorry, noob here.
Either way. Going to try the stocks and see what's up.
enjoy!
read your message after posting...but ok. Will look into the alignment right away.
Old Sep 15, 2014 | 04:45 PM
HenryNYC's Avatar
Still a Noob!
-c
Did the new after market wheels have the same hub diameter as factory? If not, was a hub centric ring installed?
Most vibrations are cause by the following after wheel swaps from my experience.
1: hub ring needed but not installed.
2: bent wheels
3: out of round tires
4: bad wheel balance
Old Sep 15, 2014 | 11:15 PM
TLCEEZ's Avatar
So went ahead and put my stocks back on and voila...no more vibration. Glad it wasn't anything with the car but now to pin point my problem with the wheels setup.
HenryNYC - The wheels did come with the centric rings and they were installed. The wheels have been balanced twice and no luck. (really doubt two places would get it so wrong). So I'm leaning towards tires. At least I hope that's the issue because if it's the wheels then I am screwed. Wheels were brand new so I wouldn't think they came messed up from the factory. I could be wrong though I guess but I hope not.
How could I tell if the tires are out of round?
Current tire setup is 225/35/20 on 9 inch rim for the fronts and 255/30/20 on 10.5 inch rim for the rears. The rears are really stretched. My thought is getting a bit wider and taller tire for the rears. I don't rub right now but I think by rolling my fenders I should be able to fit a 275/35/20 on the rear. It will be a bit more meaty and less of a stretch.
Idk...I guess little by little.
Sucks that if it's the wheel I don't think I could get it returned. I mean, they say you can't return after mounted but then how else would you be able to know? I don't know...just random thoughts at the moment lol
Old Sep 16, 2014 | 07:50 AM
lift3d_'s Avatar
rock the block
dude, road force balancing! it's different than regular balancing...
Old Sep 16, 2014 | 03:16 PM
sonny@tirerack's Avatar
Former Sponsor
Maybe this will help:
Vibration Diagnosis
Old Sep 16, 2014 | 07:32 PM
rahawk79's Avatar
Question a little off topic but did you need to install camber kits to make it fit. I'm on the fence with the s techs and just trying to get an idea of all the extra work that may come into play with a similar set up
Old Sep 18, 2014 | 04:42 PM
HenryNYC's Avatar
Still a Noob!
Based on your new info. I would probably lean towards tires. Could be out of round. Happened to me before when buying new tires. If you can't get them replaced, road force balance is the only way to go to get them balanced as best as they can get.
Old Oct 2, 2014 | 11:37 AM
TLCEEZ's Avatar
So I'll just copy what I said on another thread...
Cause? Stupid a$$ tire shop I went to get my wheels mounted at first. Basically he was having such a hard time and couldn't do it. Had to go to a second place. But the damage had been done. Apparently he tried to use this gooie stuff to make the tire slide onto the wheel. Well, he put in so much on there that there was literally a big ball of goo on my rear tire Of course...this was not seen until I bought my second set of tires and that's how I found out about this.
No balancing was ever going to take care of it. It was frustrating but you live and you learn.
Sorry for the late response. been extremely busy with work stuff..end of month is no fun for me.
Absolutely nothing else needed on mine. I even changed my rear tires to a bigger 255/35 and I think it's rubbed twice, barely! I don't even have rolled fenders.
Old Oct 3, 2014 | 11:18 PM
My god I want those wheels...
Old Oct 6, 2014 | 09:11 PM
Mellow's Avatar
6th Gear
I am having the same issue after installing my new wheels and tires. I'm currently wearing 20x8.5 +35, 255/35/20. This thread will be helpful while trying to figure my issue out. I was thinking I would need to tighten my coils (Tein SA).
Old Oct 8, 2014 | 10:59 AM
TLCEEZ's Avatar
Yeah not sure if I can help you with coils as I'm just running springs. As for the tire size, sounds to me like that should be no issue on a 8.5 inch rim.
Old Oct 8, 2014 | 12:15 PM
TLCEEZ's Avatar
Do it! $3000 with brand new tires shipped
Old Oct 9, 2014 | 12:17 AM
$3k...
I'll sit on my thumb. I have to pay off tuition first. LOL.
Old Oct 9, 2014 | 11:04 AM
TLCEEZ's Avatar
$3k...
Lol smart man
Old Oct 10, 2014 | 07:28 PM
wilby07's Avatar
Car looks AWESOME!! For a moment I thought I was looking at mines. Great set up. Smooth looking drop. You did it right for sure..
Old Oct 11, 2014 | 09:03 PM
Vidol642's Avatar
Nice car
Old Oct 14, 2014 | 01:33 PM
Booya4139's Avatar
I just replaced a set of 4 vredestein ultra sessantas with Conti DWS's, and my tire guy mentioned that certain tires on the TL tend to have vibration issues.
There are plenty of potential causes to a vibration problem, but if you've eliminated everything but the tire its worth exploring.
Old Oct 15, 2014 | 12:28 AM
Edward'TLS's Avatar
6G TLX-S
Does your tire guy know which tires will have vibration issues on the TL, so that we can all stay clear from buying those tire brands/models ?
Old Oct 15, 2014 | 12:38 AM
carbonTSEX's Avatar
The Original Shawdy
He already fixed the vibration. But I'm curious to know what brands and models cause vibration as well.
Old Feb 15, 2015 | 12:11 PM
PerilousSkies's Avatar
4th Gear
How does it ride with the lowered springs...I'm debating between springs and coils. Like everyone else, I just want the drop - not the harsh ride.
Old Feb 15, 2015 | 01:15 PM
JTL12's Avatar
First time i see a tl that looks great without a rear spoiler. those wheels make it look just right.
Old Feb 15, 2015 | 10:49 PM
csmeance's Avatar
The TL is sensitive to balancing due to the nature of the suspension design. The tire guy at your shop is stupid, the problem is not with the tires but the INSTALLATION!!!!
Continental DW and DWS tires need to be high pressure mounted. I ran though this saga on my 760 with the DW tires.
Tires are inflated to around 70+ PSI to mount them and to make sure the bead seals properly. Most shops use around 50PSI max to mount and the bead will not seal properly.
I had to have my rear wheels redone 3x before they figured it out at the tire shop. This is when the DW and DWS were brand new tires! After that, continental supposedly sent out a product information update to let installers know about this!
Old Feb 25, 2015 | 01:12 PM
TLCEEZ's Avatar
Sorry for super late reply but springs do it right for me. Basically feel same as stock, if anything, if at times it feels harsh it's because of my wheels. Colorado roads suck too.
Old Mar 11, 2015 | 05:03 PM
Supersammanyo's Avatar
Glad you got it fixed! I have the same problem with my Vossen's I bought gently used on a show car from a local Acura dealership. Getting them powder coated now and found that one of the wheels were bent. Never going back to that dealership again...
Old Mar 16, 2015 | 03:31 PM
TLCEEZ's Avatar
sorry to hear. At least you were already thinking of powder coating them so you can get it repaired and then powder.
Old Mar 19, 2015 | 09:55 PM
chrissalvatore's Avatar
TLCEEZ, I see you live in Colorado. Have you been to 3zero3 motorsports, or Colorado wheel warehouse? Looking to buy my wheels and coils from one of those places. I live in Colorado springs and places around here seem pretty shabby about there selection and work?
Old Mar 20, 2015 | 11:40 AM
TLCEEZ's Avatar
I have not checked any of those out. I bought my wheels from zygoteautosport.com guys name is Pete. Good prices and service. As for actually performing the job, I lowered it myself and just had tires mounted at Discount tire. I haven't done much other than wheels so never really needed the services of a shop.
I think you can get coils from Pete too just not sure about price since I haven't purchased any.
Old Apr 13, 2018 | 04:38 PM
chmccaff12's Avatar
TLCEEZ, what kind of wheels are those?
Old Apr 26, 2018 | 01:18 PM
Vossen Wheels's Avatar
Former Sponsor
Exclamation
Our Vossen Hybrid Forged VFS-1
VFS-1 Gallery
Now Available in 11 finishes and with an optional Sport Billet Cap
Old Apr 26, 2018 | 01:22 PM
sexy wheel!
Feb 25, 2020 09:57 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
advan031
5G TLX Photograph Gallery
Nov 14, 2015 07:44 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
Joshoats
Sep 7, 2015 09:00 PM
