TPMS sensor replacement
So the dealership wants to charge almost $300 to replace my left tire sensor. Can I get that replace at lower price. Can I also find them at lower price elsewhere.
This guy is selling it for cheap: https://acurazine.com/forums/car-par...t-more-942143/
buy it, and take it to any tire shop
I think part is around $80 each new. So with $20 unmount/mount the tire, it should cost you around 100$ for the replacement.
If you buy used, it will be cheaper. There is no need to reprogram the sensors. But if you ever need reprogramming, I think any reputable store can do it for you.
Keeping TL until 2029
Tire Rack : Sensor
had 4x 315MHz Tire Pressure Sensor @38.00 per
added when I bought snow tires and rims thru Tirerack
http://www.tirerack.com/tpms/results...dvance+Package
At least that was one for my snow tire rims and I doubt there is a difference in the stock rims however you can always ask them thru their chat
Nice thing about the Acura you can switch tires rims and sensors and the car finds the new ones in a short time without any reprogramming
Did you purchase from this seller by any chance ?
http://www.ebay.com/itm/121997925904?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITAlso, Amazon sells them even cheaper:
https://www.amazon.com/gp/product/B0...A1N26TX99XEUHY
Sensor has a new retail price of $118 with it being sold for ~$80 discounted (online OEM stores)
They're not going to install a used sensor in a customer's car, and they are going to charge them full price. So that's ~$120 right there. Then you have to remove the wheel, remove the tire, replace sensor, install tire, balance wheel, bolt wheel back up. Wouldn't surprise me if they're quoting 2 hours of labor.
Two hours of labor (~$70/hr probably) + $120 sensor = $260
Just be aware that buying the sensors used can be hit or miss. I know someone who bought 4 @ $18 each from an ebay seller, they were ok at time of installation but dead within a few months after. Had to buy a new set, so he got 4 new ones at Napa for very cheap and had them installed at a tire shop, only to find out afterwards they could not be integrated into his system. According to the tire shop it was the wrong incompatible sensor part. In the end he bought the sensors that the tire shop sold him, and returned the others back to Napa. If providing your own parts, ask the tire shop to verify compatibility by scanning each sensor before starting the installation, otherwise you may end up paying multiple times for labor.
neil0311
04-05-2016 03:36 PM
