Tire Pressure Display from KPA to PSI?
Hey guys, just curious, is there a way to convert the Tire Pressure display form KPA to PSI? I believe the U.S. models display in PSI, but the Canadian cars are displayed in KPA.......is it possible?
only possible way that i can tell is to change the brain to US spec brain.
pretty much the navigation system and the tire-pressure receiver otherwise.. its set like that..
may i ask why you want to change to PSI from KPA?
I don't know either but KPA is a pain because you can never get it exact not that a few digits on either side makes much difference. Same problem with temperature readings between F and C. The nav does however let you choose between US and metric. I find that really handy when I cross the border.
Well this is the only car i've ever had with KPA. To be honest with you, i didn't even know that KPA existed. lol. I've also only known PSI. I actually thought that PSI was the Canadian spec, because that's all i've ever known. I've just learned that KPA is actually the Canadian eqivallant to PSI.
NBP_BALLER
09-23-2015 08:18 PM
spoiler900
09-10-2015 01:06 PM
