Soften the Ride?
Soften the Ride?
I was curious if anyone has made any mods to soften the ride?
Obviously, tires could be one.
I have the 17" Michelin Pilots and I keep them at recommended PSI. Not sure if there is another tire that would help all that much?
What about suspension-shocks, struts?
Doesn't bother me that much, but my wife likes the softer ride she had with her Avalon.
Test-ride seemed much smoother, but it was same tires and same model.
Maybe it will loosen up a bit, only have 1400 miles on it now.
It's true though... Anything other than the 17's (ie, moving to 18's) are just going to make the ride stiffer feeling. You could probably try to find some different tires... but if you're on 17's (which means you have a FWD TL), then I don't know if it's going to get softer than that. The suspension in the AWD & 6MT models are even stiffer, but they bring that much better handling to the game.
Key point... if you want a soft ride, the TL is not the car for that, get a Lexus. But then you'll be totally disconnected from the road in your Lexus bubble.
It never ceases to amaze me how some people can make a big purchase like a car and then bitch and moan about how it's not fast enough....not soft enough....not luxurious enough...not sporty enough. Geezus, do some research people. ![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
gitnby, you should check to see what the tire pressues are in your car.....if it's over-inflated, it can cause a slightly stiffer ride.
PetesTL- relax. The OP asked a legitimate question and wasn't bitching and moaning. If you got nothing to add, keep out of the conversation. We don't treat new members like this.
[quote=PetesTL;11723111]It never ceases to amaze me how some people can make a big purchase like a car and then bitch and moan about how it's not fast enough....not soft enough....not luxurious enough...not sporty enough. Geezus, do some research people.
quote]
I am very happy with the vehicle, BTW. And I did a ton of research!
No different than you making all the mods on yours. I'm sure you asked questions before you spent the money?
quote]
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Gitnby - I love the ride of the FWD TL on 17s, but can't stand the look of the wheels/tires - have ordered 20 x 8.5s this week and will post pix and review my 17 vs 20s ride in the near future.
Happy trails!
You could also possibly look at getting some coilovers for your car, assuming you have the FWD version, Tein finally has a set of the superstreet model available for your car. With those you can adjust height and damper, to make the ride softer or firmer.
http://www.tein.com/products/super_street.html
Try some KW's or Tein CS's..They're pretty soft..or even Tokico struts on full soft..
The PS2's are really soft tires to begin with I can't imagine what some Nexen's or Falken FK452's would do
I've only had two personal experiences with aftermarket suspensions, one is the coilovers on my prelude and the other is my sisters Koni Yellows and Ground Control Coilover sleeves on her Prelude. Aftermarket suspensions are not designed to give you a ride that is softer than stock. They are built for the purpose of increasing handling performance. I've got my KSports on the softest setting right now and they still will punish you over any kind of uneven road surface.
If your car was older, and you thought the ride was harsh, then I would say have the dampers looked at. They're "supposed" to be replaced every 50,000 miles anyway, so you'll find decreased comfort as they approach that mark and beyond. But that doesn't appear to be the case with yours.
I disagree with PeteTL's comment that you should replace the TL with a Toyota or Lexus, obviously you should've replaced your wife with one who is less sensitive to a firmer ride
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Now have over 3000 miles on vehicle. Ride has definitely softened with some breaking in of suspension. Keep tires at 30 all-around and 32 for the highway trips. Big difference!
Something interesting about tire pressure monitor?
Running on highway, all 4 tires showed 37(started at 32) on a 60+ degree day.
Ran into some rain, and they all immediately dropped to 34.
Amazing how the rain cooled the road and tires so quickly?
neuronbob
23
07-16-2019 10:48 AM
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
