Offset for 20x9 wheels?
Old Feb 9, 2012 | 09:01 PM
hc28's Avatar
Does anyone know what the correct offset would be for a set of 20x9 wheels? With no rubbing issues.
I'm not good at searching this forum...I'm sure this has been discussed many times. Thanks.
Old Feb 10, 2012 | 08:54 AM
FYAH TL's Avatar
Chapter Leader (Northeast Florida)
offset range of +35 through +40 on a 20x9 wheel and tire size 245 35 20 will work on the 4G TL .
Old Feb 10, 2012 | 03:36 PM
KB1Spec's Avatar
For my I have 20x9.5 on the rear with +47 offset. I am running 275-30-20 offset.
But that is 9.5 and I am running staggered on a FWD TL.
Old Mar 16, 2013 | 06:41 PM
Thewavecaraudio's Avatar
Hi, I just bought a 2009 White pearl 4G TL sh awd tech and was now searching for wheel upgrade. I have done some reaserach on the forum but want to make sure like a lot of new bies.
First I live in Quebec, Canada so don't want to rool my fenders because of the salt and risk of faster rusting.
Will buy the wheel first but want to keep the option of putting on H&R sprins to get that 1 inch drop that look so nice on a lot of TL I have seen on this forum. Would like not to use camber kit.
For the tire I will keep orginal diameter since I have the AWD version and don't wan't to mess with that. So non staggered setup is what I am looking for.
So wanted to know if without the springs and wiht the springs these setup would be good? Probably for rear there won't be any problem but my concerns are for the front
Looking at the TSW Nurburgring RF Bronze 20 inch and on the cheaper side XXR 530 gold 19 inch that are coming for 2013
so for the Nurburgring (http://www.tsw.com/alloy_wheels_nurburgring.php )
20x9 ET35
20.10 ET35
For the XXR 530 ( http://www.xxrwheels.com/xxr_530.shtml ) Sure that one will fit no problem
19x8.75 ET35
Thanks for your help
Old Mar 16, 2013 | 06:42 PM
Oh yeah, forgot, sorry for my bad english I guess it is that french canadian thing :-)
Old Mar 16, 2013 | 07:43 PM
Vidol642's Avatar
I have 20x8.5 +35 with 245/35 tires and that's what a lot of us here use I think 20x9 is a good fit for +35
Old Mar 16, 2013 | 08:35 PM
Mr Marco's Avatar
20x9 ET35
20.10 ET35
Keep in mind:
Size = Weight
The weight on that 20X10 TSW w/TPMS is 25lbs. Add the tire and you are at 52lbs total per corner.
If you went with the 18X8.5 you'd be at 43lbs per corner.
Running the larger size adds almost 10lbs of extra unsprung weight to drag around on each corner of the car.
Handling, acceleration and stopping distance WILL be worse with this larger wheel/tire set-up.
Food for thought.
Old Mar 16, 2013 | 09:26 PM
Originally Posted by Mr Marco
Keep in mind:
Size = Weight
Food for thought.
That is good info, I understand weight is important if performance is the first thing in mind but since this is a car with 2x five point harness seat ( child ) in the back I have to put look before race track performance :-)
If I can refer to this thread for oem wheel weights : https://acurazine.com/forums/4g-tl-tires-wheels-suspension-298/oem-wheel-weights-874598/
The 20x10 is not heavier than the 19" oem advance wheel so eaven if inertia of the bigger wheel Will surely affect ŕ little the acceleration, I guess it could save me speed ticket in 30 mph zone :-)
Old Mar 16, 2013 | 09:27 PM
If I can refer to this thread for oem wheel weights : https://acurazine.com/forums/showthread.php?t=874598
Forgot, would the 20x10 fit without rubbing or i should stick with 20x9?
Old Mar 16, 2013 | 09:30 PM
Do you havé drop your car or dose somnole havé done it without rolling fenders?
Tanks for your answer
Old Mar 16, 2013 | 10:10 PM
Also have a look on these RJ legeng black 20x10
http://www.lespac.com/vehicules/pneu...cpZZ39WWgrZZ12
Old Mar 16, 2013 | 10:37 PM
Mr Marco's Avatar
The TSW is forged, not cast like the OEM, hence the lighter weight.
On the plus side, the TSW 20's will look so fine on the 4G TL!!! High quality wheel too.
Please post pics for us after you get them.
Old Mar 17, 2013 | 12:20 AM
Vidol642's Avatar
I'm having my car drop this weekend a lot of guys here have that setup without rolling fenders
Feb 25, 2020 09:57 AM
KB1_EJ6
Aug 28, 2016 08:25 AM
BreezyTL
Jul 26, 2016 12:52 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
