Low tire pressure?
Low tire pressure?
Wonder if any of you guys know what's going on.
I leave my car parked outside at work (garaged at home). So tonight leaving work, when I start the car to go home, the "low tire pressure" text comes up on the MDI. I check the TPMS and all 4 tires read 30psi (it's usually at 32psi). But the front driver's tire is the one specifically blinking. I figure it was due to the colder weather (~40 degrees all day).
So I drive home anyways. During my drive I noticed all the tires eventually reading 32psi, but the front driver's side tire is still blinking, and somewhat fluctuates between 31-32psi.
I get home, park the car in the garage (the garage is somewhat cold). I check it a few hours later, and it's still giving me "low tire pressure" warning on the MDI, and again points to the same tire. This time though that front driver's tire is at 30, while the others are at 31, 31, 32.
Any clues?
I gave the dealership a call, but no one is available b/c it's approaching closing hours. I'll try calling again in the morning.
Any clues?
I have had my tire pressure go down as low as 29psi cold on all 4 and it has never prompt me that it was low. See if you can find out from the manual what the cut-off is for the system to prompt you. if 32 is recommended, how can 30 be considered low?
Any clues?
Any clues?
I had this same thing happen on my '06 TL. It was a very slow leak, and only after pulling the wheel off and thoroughly checking the tire did I find a small, but long screw. I repaired the leak myself & didn't have a problem with pressure after that.
As a rule of thumb your tire pressure will change a little less than 1psi with every 10 degrees of temperature change, (pressure goes down with cold and up with heat). I've found on our 07 TL that the warning indicator doesn't come up until one of the front tires dips below 29psi but won't shut off again until the pressure comes back up to at least 30psi. The same is true with the rears but at 2psi less, (factory tire pressure is set to 32psi front and 30psi rear). To the OP, I would recommend setting all of your tires at like 35psi just to see if that will reset the low tire indicator. Once the light shuts off you can return your tires to whatever pressure you like them at.
Cold weather affects the actual tire pressure not just the pressure reading on the TPMS display.
Elevation will also affect pressure as well, losing about .5PSI for every 1000' above sea level. I noticed that on the last road trip to NY, where the PSI was about 3PSI higher than here in the mountains.Then you can avoid using those stupid sav-a-spare tires, should you get a flat or are really unlucky and get two flats!
That is very weird. I recently changed my rims and got new TPMS. My tires would not hold pressure at all. The only times the LOW pressure warning came one is when it went below 25 PSI. And it happened on several occasions after I would fill up the tires and it would decrease. I guess in really cold temperature they can expect the tires to go to as low as 25 but anything under that there has to be something wrong. For 30 PSI you shouldn't be getting a low pressure warning. And unless the dealer puts in the air or you have a good tire pressure checker it will be off by 1 or 2 each tire.
My TPMS sensors (all 4) read exactly as the tire pressure gauge that I have. The difference of a few pounds especially down to 29 psi should not trigger a warning. Could it be that you have a defective sensor for that wheel only?
The TPMS low pressure light should kick in when the pressure drops below 25% of recommended pressure. If your recommended pressure is 32lbs, then the low pressure light should kick in around +/- 24lbs (24lbs being 25% of 32lbs).
I would have the stealership check for a defective sensor. These things are sensitive and it does not take much for them to go south, or at least that has been my experience.
I was told that the system needs to be reprogrammed if you are running 19's on the AWD's as the factory recommends that they be run at 37lbs, that way you are not constantly getting the low pressure light
Oh, and I am sure that you already know this, but just in case others do not...... Never use the slime seal to fix a leak when you have TPMS.
The best ~$50 you can spend IMO is on a portable 12V air compressor (along with a patch kit) that you can run off the accessory socket in the car. Griot's garage has a nice one for $60 on their website as well as a full repair kit with 12V compressor.
No changed this morning. On the MDI front driver's side tire still flashing low tire pressure, ~31psi. All other tires fluctuates 31-32 psi. Mid 30 degrees F this morning, not sure if it matters or not.
I called my local dealership today, and made an appointment to bring the car in tomorrow. We'll see what they say.
I'll look into the air compressor. Sounds like a good idea.
Try bumping your fronts to the correct pressure and see what that does. The 25% rule is a +/- thing so at 30lbs it could be triggering your sensor. Just my
http://www.amazon.com/Viair-00073-He...=pd_sbs_auto_4
I'm very satisfied with the build quality and its performance. It sure beats trying to find one that works at a service station.
Update:
Last night at the office, I got a hold of a portable air compressor from one of my staff's spouse. I pumped the front tires (both driver's and passenger's) to 37psi (both fronts "seemed" a little sagging for some reason.) I left the rears at 32psi for now. Sure enough, the low tire pressure message disappeared. Car even drove a little better and sure footed.
This morning I called the dealership and explained what happened, and the service dept said they would have done the exact same thing, to pump air in the fronts. Service guy recommended 35psi all around.
No trip to the dealership needed, so I canceled the appointment (I would have probably gone anyways if they had the ZDX to check out
I'll definitely look into getting a portable air compressor. The one amazon seems like a good one; is there one by chance that can run 12volt and AC/DC?
)I'll definitely look into getting a portable air compressor. The one amazon seems like a good one; is there one by chance that can run 12volt and AC/DC?
Update: I pumped the front tires (both driver's and passenger's) to 37psi (both fronts "seemed" a little sagging for some reason.) I left the rears at 32psi for now. Sure enough, the low tire pressure message disappeared. Car even drove a little better and sure footed.
Congrats and enjoy!!!!!!!
Sounds like the TPMS was programmed correctly to reflect your 19" HPT. 32psi is the rec pressure for the regular tires, and I think they better at 35psi....so like TLNV said I'd probably put >37 up front and >32 rear
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
TLDude876
Dec 28, 2016 03:18 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
k6biv
Sep 10, 2015 06:37 PM
HeloDown
Sep 8, 2015 06:51 PM
