Issue re-installing suspension
9th Gear
hello guys and gals,
i am reinstalling the stock shocks on my '13 SHAWD TL. The clearance is really tight and I am having trouble getting the fork that goes onto the bottom of the front suspension back onto the LCA. I used the heel toe guide but it just says install is the reverse of removal. Any trick to get the bolt to slide back in? The upper control arm is still installed along with the steering knuckle. Thanks!
get a person to stand on the knuckle/rotor/lug area to help bring the suspension down
It's a lot easier if you unbolt the upper balljoint from the knuckle. Just make sure you don't pull the knuckle out too far from the car on you can separate the inner joint on the axle.
