How accurate is the TPMS?
My Tire Pressure Gauge and TPMS are 4 PSI off whether tires are hot or cold. I recently purchased a new tire gauge and it falls in between the 2. Which one should I go by?
Can you calibrate the TPMS somehow?
6G TLX-S
I'm using a digital tire pressure gauge with spec accuracy to within 0.5 PSI.
When checked against the TPMS displays for my set of summer and also my set of winter wheels, the numbers are off by not more than 1 PSI.
Account closed
1 or 2 PSI is not going to cause that much problem between your gauge and the TPMS
If you ar a "bit" anal/OCD like me, I filled mine until my display matched (needed an extra .5 in the left rear)
Received 6,470 Likes
Pack, I think the answer is "good enough". 1-2 pounds should not make that much of a difference.
neuronbob
23
07-16-2019 10:48 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
