Good Wheel and Tire Combo?
I have a stock 2009 FWD tech tl.
Wheels: ASA GT5 19" x 8" wheels, +45 offset, 5-114 bolt pattern, matte black finish, 1 PC. Cast & shot peened
Tires: Hankook V12 Evo Ventus K110, 235-35-19ZR
Is this a good combination for my tl? and is 825 a good price for em?
Rims has very minor scuffs on the back side of it, but thats it.
I kinda wanted a 20" look, but not sure how it would fit. Is it a quick and easy car shop fix to get spacers and whatnot done to fit 20" if i decide to?
6G TLX-S
The bolt pattern for the 4G TL is 5x120, not 5x114.3.
I dont know anything about tires/wheels, im a noob at this stuff. Can you explain to me please what it means if the bolt pattern is different? Can i not use this rim/tires at all?
And could you answer my questions about any necessary car changes if i want a 20" wheel? Could you suggest an affordable black wheel 20" combo with a specific tire?
you want atleast a 245 width tire.. your stock tire width is 245.. i would not consider a 235 tire.
bolt pattern is like socket wrenches.. if a bolt on your car requires a 10mm size socket.. it can only fit a 10mm size socket
bolt pattern is the same thing.. your car only takes 5x120 pattern wheels..
personally i would not even bother with those wheels, its junk to me.
where you located at?
sockpuppet (08-11-2014)
Heres some more images I scrounged up, if you wanted a feel for the look. http://imgur.com/a/ySqj9
I am located in Long Island, New York.
I like the look of the Asa Gt5. I actually got the desire for it after seeing that picture ^
What other recommendations would you have other than the asa gt 5 then?
Okay thanks for the info above guys. But I was wondering if this is true. The bigger your wheel, there will be less steering power? And your tires on your wheel will have less tire life?
rock the block
your turning radius will decrease a bit depending on how big you go
your spedo may be off 0.5 kph or so, that's what i found with my 20" setup
depending on what your tire setup is, you may have less tire life - if you go stretched and/or staggered for example. if you do OEM specs on the tires, i doubt you would notice any difference in tire life.
hope this helps!
hope this helps!
asahrts
09-04-2015 05:55 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
