Camber Adjustment
Camber Adjustment
Tried searching the forums, couldn't find anything.
Can we adjust the camber on our cars? I read that we had to buy a camber adjustment kit.
But i can't seem to find Front camber adjustment kits, just rear. Getting tired of buying new tires every year because the inside of the tires wear out too fast.
And i always get an alignment once I have new tires mounted and balanced.
Could you link me to some camber kits i can install?
The Original Shawdy
Brandon J. Downhour (12-17-2017)
These two main kits that poeople but including myself. Either SPC or Ingalls (I’m. Sure there’s some generic brands out there). SPC makes a 3 bar kit for the rear and adjustable ball joints for the front. Ingalls offers adjustable ball joints for front and rear and only camber toe arms for the rear. Best option is SPC but is much more pricey. I originally went Ingalls rear and replaced it with the SPC 3 bar kit. I did leave the Ingalls adjustable bal joints though for more adjustability. The fronts I added SPC ball joints. Keep in mind the front can be hard to reach so removing loosing the fork is the easiest way to bring the ball joint down. SPC rear is much easier to adjust. You can purchase either through heeltoeauto.com. Good luck!
carbonTSEX (12-19-2017)
danny_isr
11-26-2007 09:01 PM
