20" wheels
20" wheels
Will 20" wheels on stock height make the car sit higher off the ground by an inch or so??
Going from Oem 17" to 20" aftermarket is gaining about 3" in diameter but the low profile tires will offset some ground height on 20" wheels?
Please chime in
Please chime in
so, your overall diameter should be about the exact same dependning on tire choice...
Stock 17" wheels have 50 series tires...
18" have 45 series
19" have 40 series
20" have 35 series
So the tires get thinner to offset the bigger diameter wheels... Where it gets a little tricky is the tire width... If you have 8-9" wide wheels people usually go with a 245 width, if you go 255, those will be wider and slightly taller
there are tire calculators on the web where you can compare you stock setup and whatever you want to get to see the difference. But in general it will be marginal provided you follow the above recommended series tires.
Some who want to slam their car or run high offset wide wheels will stretch tires or run thinner tires to get them to fit. Not necessarily recommended.
18" have 45 series
19" have 40 series
20" have 35 series
18" have 45 series
19" have 40 series
20" have 35 series
18" have 45 series
19" have 40 series
20" have 35 series
that's a lot of tire. 275mm is 10.8" wide. it'll look mean but i don't think your fenders will handle it without a lot of work and some camber.
Sorry, I didn't take any pics, only had the wheels on for 500 miles or so. There was nothing wrong with the setup, but I really want to go with the 19" diamond cut that Acura offers.
Well it was needed on a 10.5" wheel with an AWD system to get as close as possible to the same rolling diameter of the front tire that was 245/35/20. By the way when people throw a 245/35/20 onto a 10" wheel, that tire is pretty much now a 30 series with the stretch. My front tires were on a 9" wheel and there was no stretch at all. So the 30 series on the rear was needed.
JByron
Jan 8, 2016 09:49 PM
