20" MRR HR6 Staggered Fit Question
Old 12-14-2011, 10:17 PM
8th Gear
dditty708's Avatar
I just picked up a 2012 TL with Tech and wanted to put on a new sit of rims. I would like to go with 20" MRR HR6 Staggered 20"x9" 245/35/20 and 20"10.5" 265/30/20 with an Eibach Pro Kit drop. Will they fit without any rubbing issues? Also, is there any other TL's running a similar staggered setup? I have searched but havnt had much luck. Thanks in advance.
Old 12-15-2011, 08:35 AM
gibbyisgibby's Avatar
10.5 on the back seems rather wide im not 100% sure if that will fit without modification.
Also im not really familiar with staggered setups but is there a reason why your running 35 series on the front and 30 series on the rear?
Old 12-15-2011, 08:48 AM
8th Gear
dditty708's Avatar
I Was thinking the same thing, but some rim retailers are telling me they will fit. I see that a guy with M6 wheels had to shave 4mm off the inside of the rear rims. I do not want to do any mods to the rims or the car to make them fit.
Old 12-15-2011, 08:27 PM
Well potmilkz is running a 19" similar staggered setup:
https://acurazine.com/forums/4g-tl-tires-wheels-suspension-298/19x8-35-19x10-30-tire-size-need-opinion-822191/
Old 12-18-2011, 07:22 AM
HeartTLs's Avatar
Eibachi springs
Old 12-18-2011, 10:20 AM
Mr Marco's Avatar
Originally Posted by HeartTLs
Eibachi springs
Yep, the Eibach's will just cause the OEM struts to fail.
OP, do it right and buy the Tein coil-overs.
HeartTLs (12-18-2011)
Old 12-18-2011, 07:29 PM
8th Gear
dditty708's Avatar
I don't want to go coliovers why not Eibach? I have had them on 2 other cars with no problems. What springs for about a 1 inch drop would you recommend?
Old 12-18-2011, 08:08 PM
Pete2010's Avatar
Go with H&R's they are much better quality - I've heard the Eibach's are far too harsh.
Old 12-18-2011, 10:35 PM
HeartTLs's Avatar
Damaged OEM struts is exactly what happened to a member/friend on AZ with a 3.5 TL.
Get Tein or H&R springs instead.
Old 12-19-2011, 08:57 AM
8th Gear
dditty708's Avatar
I will look into Tein and H&R thanks.
Old 01-12-2012, 07:37 PM
KB1Spec's Avatar
Running 235/35/20 fronts and 275/30/20 rear with Tein SS and not rubbing issue and no fender roll and not finger gaps all around.
Old 01-12-2012, 07:46 PM
5th Gear
10TL's Avatar
go with h&r springs.. eibachs are good, but the h&r seems to be working well with the TL. good luck!
Old 01-12-2012, 07:56 PM
8th Gear
dditty708's Avatar
KB1 can I see some pics?
Old 01-12-2012, 11:03 PM
KB1Spec's Avatar
Old 05-21-2012, 02:15 PM
Straight outta JERSEY ...
mrchoopa2u's Avatar
very nice
Old 05-25-2012, 07:07 PM
Zutt's Avatar
Nice... I want to black out my black 2012
Old 06-05-2012, 07:07 PM
purextc's Avatar
I like it!
Old 07-07-2012, 02:54 PM
ZVP
ZVP's Avatar
anybody knows the parameters of those tyres?
http://acuraconnected.com/2011/09/07...photo-gallery/
drone619
01-26-2016 07:09 PM
wusty23jd
09-24-2015 11:41 AM
datadr
09-12-2015 09:12 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: 20" MRR HR6 Staggered Fit Question
