Wiring?
Old Jul 15, 2012 | 07:45 PM
EkSoni's Avatar
Wiring?
Just a quick question I used this cheap hit kit I got off someone because I was impatient well I think I burnt my wiring anyone got an idea of how much it is to fix?
Old Jul 15, 2012 | 08:32 PM
potmilkz's Avatar
exactly what is wrong?
Old Jul 15, 2012 | 09:09 PM
si1point6's Avatar
When you say you think you "burnt your wiring", is the insulated sleeving on the wires really burnt? If so, you may have shorted something and caused a lot of current to run through that wire causing it to "burn". Take a look at your owner's manual and find the fuse associated with the light you are working on (DRL, foglight, HID, etc). If the fuse is blown, replace it with another fuse of the same amperage, reinstall the stock light back on, and see if the light turns on. If not, you may have to take the TL in for troubleshooting and potential repair.
Old Jul 15, 2012 | 09:15 PM
EkSoni's Avatar
Well I guess the hid kit i used blew out my fuse so I just replaced the fuse & it works with original bulbs but Im going to get relays & then put back the kit but thanks guys!
Old Jul 15, 2012 | 09:42 PM
si1point6's Avatar
I'm glad you were able to get your car back to its original state and operating. Good luck with round two of the installation after you get the relays.
Old Jul 15, 2012 | 11:03 PM
EkSoni's Avatar
Lol thanks even though I know I'm goin to be lost while wiring relays :/
Old Jul 15, 2012 | 11:33 PM
Edward'TLS's Avatar
6G TLX-S
If you can explain your situation in more detail , some of us may be able to help you out.
A lot of members here have experience installing HID kit on their own.
Old Jul 15, 2012 | 11:43 PM
EkSoni's Avatar
Oh thanks man I figured it out was really just my fuses. But just to make sure it doesn't happen again I'm going to add relays to my hid kit but one idk if I really need them 2 idk how to wire them up once i buy them lol
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
