Vibration around 60/70mph....Axles maybe?
As the topic says....could it be my axles? Under acceleration I get vibration especially around 60mph. If i get to 80mph on the highway then you don't feel it as much....if I let off the gas and coast you don't feel it at all. Rims and tires have been balanced...both stock and aftermarket rims so I know it's not that and I have new tires on both. So far from googling, it's possibly the axles....i was told there was 3 axles...one on each end and then a intermediate one...where is there an intermediate? And how can you determine if it is even the axles because I had one shop look and from just driving it and visually looking they can't see if it is the axles 100% but they think it is. Is there a sure fire way to know exactly if it's axles. By the way there is no clicking when turning and the transmission shifts fine. Any help is appreciated. Thanks.
Could be engine mounts too. Front, side, rear... have a dealership check them for cracks etc. The front mount is an active one. Look for any vacuum leaks from the tube that goes from the mount to the manifold.
Ive had all wheels rebalanced and mounted...the stocks and my 20in and both sets have new tires so I know its not the rims or tires. Plus I have a daily so I dont even drive it except on the weekends.
Fyi my car is Fwd also. The vibration is felt after 45mph under acceleration, then sort of stop above 80mph. But then it will start vibrations again a little but after. But it's definitely felt at cruising around 60/70.
Would engine mounts really cause that vibration? it feels as if the wheel might come off under acceleration but fine when its coasting.
Take it to a dealer for a proper diagnosis by the book.
let me guess. It is probably TC issue.
I have same feeling when running around 50- 60 miles with gas pedal hit. When I let it coast at that speed range, the vibration goes off. I guess that is TC. I noticed at 50- 60 speed range, the rev is around 1200 which is the range to replicate the TC issue. At that speed range if you hit the gas pedal more to let the rev go above 1500, even your speed still is around 60, but the vibration goes away.
A bad mount will cause vibration at a given RPM range, unaffected by vehicle speed. Run it through the gears and see if the vibration happens at a certain engine speed in every gear. If it doesn't then its part of the drive line or suspension.
I thought that the torque converter issue was only with AWD....my TL is FWD auto.
I'm battling this issue for 2 MONTHS now. To be fair my service guy has tried everything. I have one new control arm, ALL new motor and trans mounts. Took it back for a pretty violent vibration, shook the steering wheel. diagnoses, BOTH axles bad.
Took a month to get them in, finally put them on, one OEM and one aftermarket. I drive and the vibration is still there, not as bad, but very apparent, and only when you go near the gas pedal. Hi and low speeds don't matter.
They think its normal, I even road with tech and while I am in the backseat, I feel it in the floor board bad. They now cant confirm until they can drive another 5 speed to compare.
Could a wheel bearing cause a loud click/clunk when reversing then going into drive? It's quite pronounced. They say normal axle play.
the last 6 months have been a nightmare. I'm tired.
Vibration under acceleration = Axles
Vibration at certain speed zones IE 60-72MPH or 82-90MPH, etc = Bent Rim
Vibration at speeds higher than 45+ that does not go away but may get worse = unbalanced tire.
swap out the aftermarket one for an OEM one and the issue should go away. Also get the tires road force balanced.
Problem with axles, it took them a month to get the aftermarket one. This was all done by Acura. I'm thinking maybe that aftermarket one is bad. The problem improved but not solved. Apparently they didn't have a supplier for axles.
Does anyone else have a mild to moderate vibration they feel during acceleration?They're trying to say this might be normal.
Sounds like both of you need to fire the mechanics you are going to. Just awful replacing all that shit and it doesn't even fix the issue.
Ok so. I will post some things that effect drive ability and vibration.
Bad tie rods.
Bad ball joints.
Bad U Joints.
Bent rims.
Belts shifted in a tire causing un-even balancing requiring a lot of wheel weights.
Bad or broken stabilizer links.
Bad engine mounts.
Bad drive shaft.
Wheel bearings.
Let me know exactly where the vibration is coming from and ill try help as best as I can.
That clunk when reversing is normal on these cars.
Might actually be the style of tire you are driving on too... sometime when you hit a certain kilometer or mph range with 1-6 mph or 1-10 km/h you'll feel a vibration in the gas pedal coming from the tires. As I said I need to know exactly what is going on. Where you feel the vibrations. Steering wheel, pedals, everything.
Bad tie rods.
Bad ball joints.
Bad U Joints.
Bent rims.
Bad engine mounts.
Bad drive shaft.
Wheel bearings.
Also I'll add that you might have unbalanced tires and hopefully the shop you went to didn't static the weights on one side or they havn't calibrated their balancing machine in awhile.
Great points guys. My advisor at Acura is cool and knows I'm gonna bug him, but that doesn't mean the tech is gonna find the issue. I can tell you both the dealer and the Discount I go to very often did a road force, spun the tire on the wheel. I have the good Michelin tires on it, lots of tread, never hit any hard bumps, car used to ride like a dream.
The thing is the vibration was improved after the 2 axles where replaced. Also one control arm has been replaced. The vibration is only felt on acceleration though, so it seems if it was many other things it would be there even when coasting. But once its not under load, all is quiet. I even felt it in my feet when I road in the back with the tech.
Again, all engine and trans mounts are new, passenger control arm. I am thinking since issue improved but not solved, maybe that one aftermarket axle is bad. Like bad inner joint. I would assume that they checked everything possible, but I know that's like believing in unicorns. I am waiting to put my jpipe and exhaust on because I don't want them blaming the vibration on that.
mpossible (01-06-2024)
That's my next step. Problem is that the dealer said they couldn't get them, no supplier I guess. At least he gave m I will check again though, because the vibration is starting to get worse.
And now I got an airbag that may kill me or mess up my pretty face.... I still love my car though. Carbon, I need them wheels you got, dang.
Bad tie rods.
Bad ball joints.
Bad U Joints.
Bent rims.
Bad engine mounts.
Bad drive shaft.
Wheel bearings.
Bad tie rods.
Bad ball joints.
Bad U Joints.
Bent rims.
Bad engine mounts.
Bad drive shaft.
Wheel bearings.
