Valve adjustment
Old Nov 12, 2024 | 12:43 AM
4GeezTL's Avatar
Valve adjustment
replaced valve cover and noticed the discoloration on cylinders 4,5 and part of 3.
Thoughts?!
car is 2012 TL 3.5 with 165,000 miles
Old Nov 12, 2024 | 07:03 AM
altair47's Avatar
Thoughts?!
This is a design feature of all J engines, yours is very clean under the cover.
Old Nov 12, 2024 | 08:05 AM
4GeezTL's Avatar
interesting! I had read something about air flow or the heat flow of the engine as being why some cylinders get burnt.
I also read that tight valves can cause burning? I adjust some of valves in the front, they were tight.
car now ticks more than before the adjustment.
Old Nov 12, 2024 | 09:37 AM
dvd2012tl's Avatar
Second Altair47, Your valve train looks pretty clean. The J35 crankcase ventilation system runs all the piston blowby gasses into this valve cover and back into the upper intake plenum through the hose on the passenger side of the front bank valve cover. You had to take off that hose to remove the valve cover. Your seeing a some staining of the rocker arm assembly as the gasses make there way into that hose and back into the intake.
Old Nov 12, 2024 | 03:06 PM
4GeezTL's Avatar
That’s a relief to hear! Thanks
Yeah the PcV is on the right of the front valve cover and there is a slotted shield that runs along the top/ underside of the front valve cover. Exactly like you say, that is circulating gases causing stains.
I was worried something was burning or tight valves causing an issue.
thank you both!
Barnaby
2G RDX DIY & FAQ
Sep 10, 2024 03:00 PM
ThatBlackTL
Mar 14, 2022 05:52 PM
SRK141
Oct 22, 2006 04:06 PM
mdavisii
Jan 6, 2005 10:34 PM
