Turn signal or Hazards not working
I was changing my front turn signals to the switchback LED’s that many have done on this forum before, i bought the recommended bulbs and resistors. When i was installing the passengers side LED bulb and resistor they were plug and play. I went to turn on the lights to make sure they turned on white, but when i turned them off amd tried turning them back on the light did not work anymore. I have tried placing the factory bulb back, but that does not do anything. Nothing that i have seen looks burnt. I plugged the drivers side switchback in and the light does turn on white with no problem. However when i try to turn the turn signals on nothing happens and the hazards fo not turn on aswell. I do not know what else to do. Any help would be appreciated! Thank you
Acura TL (2012) ? fuse box diagram | Auto Genius
According to the site above, the Hazard fuse is #9 in the under-hood fuse box. I couldn't find anything for signals either but there's various fuses for exterior lights that you might try for good measure if the hazard fuse doesn't work. There's also Left and Right side small lights, 27 drivers side and 2 passenger side that are worth a try.
Do you hear the clicking when trying the turn signals or hazards?
coudl be bad bulbs too
JCL622
11-24-2015 07:39 PM
badnewzplayaz
08-15-2014 07:39 AM
