Tugging/Pulling feeling while accelerating
I have a 2010 Acura TL and I am experiencing what feels like a tugging/pulling feeling while I accelerate as well as when I release the gas pedal. Its much more noticeable going at low speeds 20-60km / hr. When I drive and go around 2000 rpm it feels as though the car is being tugged/pulled backwards. There is a bit of a tug/pull when I apply the brakes as well.
Does anyone know what could possibly be causing this? Or what to check for that could be possibly causing this? There is no code that appears on the dash but I definitely notice something is different when I drive.
Car specs:
- Automatic
- 80,000 KM
- RWD
- Technology Package.
Any help would be appreciated!
Thanks in advance.
Car specs:
- Automatic
- 80,000 KM
- RWD
Thanks in advance.
Are you pulling to the left or right when you feel the tugging? Any noises when it happens... if so, what does it sound like and what part of the car does it seem to be coming from?
Its pulling backwards. Its hard to explain, it feels as though the car is stalling and struggling to accelerate hence the pulling/tugging feeling. There is no noise when it happens and it seems to come from the engine area or front of the car.
Considering the fact that your car is RWD, there must be numerous modifications to your car, anyone of which could be causing the "tugging" ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
On a serious note, prob is the alignment
You need an alignment. Your toe is probably out of spec. Also check your tires too.
Yes it sort of feels like that as if its struggling to accelerate
If your toe is out of wack meaning the wheels are not pointing straight like it's supposed to (mainly it's front wheels) then it will not steer straight. It sounds like you need an alignment since you haven't done one in quite some time. You will need a 4 wheel alignment. Supposed to be every year. It def has to do with your suspension though.
2011 SH-AWD 6MT
You could have more than one problem. You mentioning the symptom developing at a certain RPM indicates to me there may be something related to the motor (maybe MAF sensor).
I definitely agree you should have the alignment checked. I would also see if there are any trouble codes stored (despite no CEL).
Mine seems to do something similar only in 2nd gear on heavier acceleration. The car doesn't seem to accelerate smoothly and feels like something is out of round. It has done it since I bought the car new.
It is really bad on the 1-2 shift, it is like a bog then the rpms tremble and the car finally resumes acceleration.
mlody
12-04-2019 02:11 PM
joflewbyu2
08-18-2019 10:38 PM
Eggs999bacon
09-24-2015 10:08 AM
