Trunk Light Fuse
Trunk Light Fuse
Anyone knows if there's a fuse for the trunk light? I installed a set of LED a while ago and all of the sudden it didn't light up. I try to replace with another LED light and it didn't work. I put back the stock 168 bulb and same thing. Just want to see if there's a fuse? I look into the manual and no luck.
Yes, I did check slot #16 They all works. Just the trunk didn't work. I also didn't mention this but it wasn't a biggie but the passenger side door under light doesnt work too. I think while I was installing my LED panel, I was trying to take out the stock light with a pair of plier and I guess it contacted against metal to metal and now that doesnt light up. I think I might burnt the module or harness. I check the fuse as well. nothing blown.....
By chance do you know which harness was it? Ive been looking online but I can't narrow it down. Did it take your friend that long the change it out?
so what exactly is wrong with the trunk light???
i checked the fuse also in the engine bay. its fine.
i got the same issue as you.
how did you solve it??????? help please!!!
Did you swap out to some LED bulb on the trunk? I will need to find my wiring diagram. Because the wiring harness is on the front passenger side fuse box area.
But sounds good hopefully I am having the same issue!
So I went to the dealer today to have them check out the trunk light. KB1Spec was right! There is a fuse and wire harness in the passenger side fuse box. They ordered the part. It should be there in a few days.
I didn't know there was another fuse box or is it a hardness with a fuse together?
Either way I'll have the dealer check as well. I need to go anyways. So they can check the atf external filter and get that fixed as well.
Well that filter is making this funny sound when I start the car up first thing in the morning. Its very common you can find people talking about it all over the forum.
It's just the filter needs to be replaced. And once again they don't want to listen to me. They want me to leave the car with them over night. Which I am not comfortable with.
Acura wants to inspect the car first so yeah. A hassle.
Good to know they solved your problem! How much was the harness? Because my friend just did it for me for free. Just curious
Ok so I finally got my car back. Below is the part they replaced. This should help.
Home > ACURA > 38200-TK4-A12
ACURA BOX ASSY., DRIVER FUSE (38200TK4A12)
Sale Price: $214.60
List Price: $306.57
You Save: $91.97
Part Number : 38200-TK4-A12
Sale Price: $214.60
List Price: $306.57
You Save: $91.97
Did you installed the original bulb back before you took it in?
Are you going to install the LED back in the trunk? Lol
All this was covered by the warranty right?
They had my car for 2 days because they said the first part that came in was defected from the factory. So they over nighted it the next day. When I took it to the dealer i put the original bulb back in because I didn't want to them to say I was the reason why it was bad. As soon as I got home I verified that the light in the trunk goes off when I close it by looking through the passthrough in the back seat. Then I reinstalled the led bulb. It works great. All of this was covered in the warranty. I didn't pay anything.
So far my courtesy and license plate led lights are holding up good. No issues there.
Did you have to mention the car is under warranty etc, or they just took your car in and you walked out with a fixed car without saying a word about the warranty.?
Sorry about the questions. Its that this is my first "new" car. Lol.
Awesome, looks like I will have to take the care in very soon, but this will take a day at least. Sucks, hopefully the led doesn't mess up your wiring again... I am afraid of installing it back and doing damage lol.
Hey don't worry about asking questions, that's why we are here to help each other. But I put the led back in already just make sure that no metal between the two leads touch. I would suggest to unplug the light fixture from the harness and plug in the bulb before connecting it back to ensure no metal between the lead touch. I didn't say anything about the warranty. They treated as a factory defect.
Thank you!, i appreciate the info, yes i did that when i installed the LED to prevent any shorts etc.
i made an appointment for tomorrow 6/16/14 at 9am.
let see what happens
i will you guys updated!
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
drewdeezy03
Sep 3, 2015 08:04 PM
