Transmission Gurgling and Shuddering
Old Sep 30, 2019 | 04:30 PM
  #81
mrphilipanderson's Avatar
Originally Posted by KingAc
Thanks bro I have a 3.7 I’ll look into that for sure. Other than those 2 problems the car is a nice car I just want to get these issues fixed. What transmission oil, engine oil and rear differential fluid do you use if you don’t mind ?
i ONLY use Acura brand Fluids for my car its cheaper than other fluids where I live and they have on record each time Ive purchased the oils to do them myself:
Acura Transmission Fluid (ATF DW-1) Drained 4.3 Quarts Out, I put 4.3 Quarts In
Transfer Case: HGO-1 (Hypoid gear oil)
Read Differential: Acura AWD (All Wheel Drive) Fluid 3.5Qts
Dont forget Crush Washers for Drain and fill plugs.
Old Oct 4, 2019 | 06:48 PM
  #82
dregsfan's Avatar
Thanks bro. I complained to my dealer about it The dealer changed my transmission oil and then had to order the filter for me then I had to go back for them to change it I’m still getting the sound. do you change your transmission oil your self ?? I’m thinking about just buying another filter and getting a transmission oil and doing it my self any recommendations ?? And I’m going to order that injector online hopefully I can find it on amazon. Also what is a “TSB”?? Thanks man
Technical Service Bulletin. You can find them listed here:
https://acurazine.com/forums/fourth-...inside-945434/
hiyou52
May 7, 2015 08:51 AM
energie
Jul 22, 2008 02:42 AM
mschloss
May 22, 2006 03:17 AM
bebop.fey
Apr 19, 2005 07:51 AM
Todd
Aug 9, 2003 11:47 AM
