is timing belt/water pump a difficult job?
Old 03-02-2024, 08:32 AM
gentlejax's Avatar
I have done mots of the work on my cars but as I am getting older I dont feel so much like it anymore. Just bought a 2013 with 130K miles. I dont know if belt service was done. need to see if I can identify that .
if it is old I would think it would/could snap any time now, but I wouldnt think it would last that long.
anyhow. is the job too much to do in garage on floor? I dont have a lift to put car in the air and such. I have tools . lol..
Old 03-02-2024, 09:45 AM
Strandskogen's Avatar
I have commented about this in the past but basically removing the crank bolt itself is the 'make-or-break' part of the process. If you can't get that off successfully, you cannot go any further. I had replaced a timing belt on a similar Honda Pilot V-6 where the bolt was difficult to remove but not impossible (Even used normal floor jack - no lift).
When I tried to perform the belt replacement procedure on my 2012 3.7 TL, I couldn't get the bolt to cooperate and in the process I broke two heavy-duty breaker bars plus chipped a piece off the crank itself (You will need a special 'holder' to hold the crank while you try and loosen the bolt). I am guessing that I was applying at least 200 ft/lbs of torque plus tried all the tricks of spray lubrication and torch heating.
I ended up taking it to have Acura do it. Hope that gives you an idea but I would suggest taking off the passenger side wheel and see if you are successful at taking off the crank bolt. If not, take it somewhere and have them fight with the bolt on a lift.
Old 03-02-2024, 08:00 PM
altair47's Avatar
Ukrainian life hack, order Milwaukee 2767-22 and Lisle 77080 on Amazon, easily unscrew this bolt, and then return it.
rexflexall
12-16-2017 12:21 PM
Andy74
10-10-2012 11:40 AM
RidinDurty
02-14-2007 04:42 PM
18anatak
09-12-2005 09:51 AM
EezyE36
06-11-2002 04:50 PM
Quick Reply: is timing belt/water pump a difficult job?
