Tans Performance after Fluid Change
Old Sep 19, 2013 | 04:18 PM
SilverMike's Avatar
Hi all,
A few weeks ago I had the dealer replace the trans fluid as the existing fluid was getting pretty dark. I noticed the trans (5sp auto) shifted more smoothly the the following couple weeks. However, this week it's feeling as bad or worse than before. Why the sudden change in behavior? This trans is really driving me crazy, especially between 0 and 20mph. And every time I accelerate onto an incline it bogs down.
Any ideas or suggestions?
Thanks!!
Old Oct 17, 2013 | 07:02 PM
Reorge's Avatar
Did you change the trans filter. I think all Honda/Acura post 2003 V6 trans have one. Some can and some can't be changed without removing the trans. Do a Google search and you'll find info about this. My mechanic friend told me that new fluid has some detergents in it that cleans the crud that the old fluid couldn't anymore. He also said if you have issues a short time after a fluid change the filter might be clogged. It's just might be one item to check per his advice.
Old Oct 18, 2013 | 02:45 PM
jim_c's Avatar
I believe trans filter is internal. Trans does not have a traditional pan nor any access like older model automatics. That is, not a maintenance item.
Old Oct 18, 2013 | 03:42 PM
Mr Marco's Avatar
^+1
Old Oct 19, 2013 | 12:46 PM
Reorge's Avatar
Although Acura does not consider it a maintenance item 2000+ trans have an external filter. Some years (07-11 I think) are behind the torque converter and are inaccessible.
Examples:
2000=25450-P7W-003
2006=25450-RAY-003
2012=25430-PLR-003
https://acurazine.com/forums/3g-tl-2004-2008-93/c-036-diy-transmission-filter-replacement-pics-787078/
https://acurazine.com/forums/2g-tl-1999-2003-98/transmission-filter-706003/
There's lots of info if you search the web.
Old Oct 20, 2013 | 02:53 PM
jim_c's Avatar
The video relates to a 2000 TL.
Again, I was told that the filter on my car (2010 5AT) is internal, meaning "inside the transmission". To change it, that trans has to be dismantled. Is that right of wrong?
Old Oct 20, 2013 | 03:58 PM
Reorge's Avatar
After some research I found you have to "drop" the transmission to change it. Technically its external but inaccessible nonetheless. It's behind the torque converter. This applies to 2007-2011 TL's from what I could find.
Filter part number = 25450-P4V-013
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
NitroViper
Mar 20, 2017 09:50 PM
nanos
Nov 12, 2015 08:41 PM
Aleax
Sep 11, 2015 11:31 AM
