Stiff Brake pedal at first start
Old Jan 30, 2018 | 07:51 AM
BobsUrUncle's Avatar
Angry Stiff Brake pedal at first start
All-
2014 TL FWD Advanced Pkg, just had the car in to the dealer for ~40k A1 service last Thursday. I had them look at the brake system because the past month or so I go to start the car, and the brake pedal is stiff, almost to the point that it won't depress far enough to trigger the starter. They diagnosed a Brake Booster Hose failure, ordered the 46402-TK4-A01 part. It didn't come in until late Friday (good thing I got a loaner), and they replaced the brake booster hose. They call me Monday morning to let me know the car is ready. I go to start the car in the lot (about 30 degrees outside), and the brake pedal is still stiff. I figure, probably didn't build enough vac after they pulled it outside. Drove home about fifteen minutes.
Go out to the garage this morning, its about 30 deg in the garage, and depress the pedal...still stiff. I am not noticing any issues while driving. Thoughts? Anyone have this issue in the past?
Old Jan 30, 2018 | 11:14 AM
Teddybear's Avatar
Subsonic
Mine did that for years. It would be stiff if parked anywhere from sitting overnight, to getting gas. (more rare). Timing seemed inconsistent. Dealer kept telling me it was normal.
Then one time a few days after a brake flush, the brakes felt different all of a sudden, and the stiff pedal never came back. I had done multiple brake flushes before this one, and the stiff pedal was always there.
Before anybody goes off, it's been years since that happened and the brakes are still perfectly fine.
Edit: with that being said, you should probably still get it checked out by an independent mechanic, as i did, just to be sure.
Old Jan 30, 2018 | 11:16 AM
When was the last time the fluid was replaced?
Old Jan 30, 2018 | 02:09 PM
As far as I know, never. The car is just short of 40k miles on the odo. Bought it from the dealer with ~5k mi on it, serviced there ever since.
Old Jan 30, 2018 | 02:20 PM
Brake fluid is hygroscopic meaning it absorbs water. Water freezes. It may explain the stiff brake pedal in the morning when it's colder out.
Old Jan 30, 2018 | 03:51 PM
Right, but as soon as the car starts, it is fine. Seems more like a vacuum thing to me. Perhaps a bad master cylinder (or whatever they call them these days).
Old Jan 31, 2018 | 04:17 AM
Edward'TLS's Avatar
6G TLX-S
There was a thread on "hard brake pedal when starting vehicle especially on cold winter mornings" back in 2014 :
https://acurazine.com/forums/3g-mdx-...rnight-898831/
Old Jan 31, 2018 | 04:20 AM
Edward'TLS's Avatar
6G TLX-S
There is no permanent fix on this problem.
Old Jan 31, 2018 | 06:45 AM
rockstar143's Avatar
I feel like this has to be a brake booster issue itself...not just the hose.
Old Jan 31, 2018 | 08:40 AM
Thanks for the link, but when going through that thread (and subsequent threads linked to it), it doesn't appear as if anyone had a resolution other than "when it is cold, it does that in your car".
Old Jan 31, 2018 | 08:41 AM
It only seems to happen in colder climate areas, from what I am seeing in the threads referenced.
Old Jan 31, 2018 | 11:31 AM
JM2010 SH-AWD's Avatar
I'd try changing the fluid. Brake fluid can become contaminated with minute quantities of water over time. It doesn't take much to mess with the braking action.
Old Jan 31, 2018 | 12:01 PM
dregsfan's Avatar
Yeah brake fluid should be changed every 3 years. Your '14 is due for a change if it's never had one.
Old Jan 31, 2018 | 08:23 PM
EE4Life's Avatar
Forum Contributor
2014 TL - Brake Booster Test
https://techinfo.honda.com/rjanisis/...untry=1&lang=0
mynameisjacob
4G TL Problems & Fixes
23
Nov 19, 2019 06:21 AM
Jcwx5
Aug 25, 2017 11:32 AM
aerospike16
2G RDX Problems & Fixes
Aug 24, 2015 09:10 AM
sabohead
May 4, 2013 01:28 PM
ostrich
Sep 24, 2010 05:57 PM
