Specific oils to slow consumption of SH-AWD
Old Sep 14, 2022 | 04:45 PM
ragtophardtop's Avatar
Has anyone found a particular brand or weight which slows consumption? I've only changed oil at the dealership until the warranty was up, so I've only used the factor 5w-20 semi-syn. I am considering dropping in a 0w-30 synthetic, or maybe 5w-20 mobile 1 High Mileage or something similar, and measuring consumption with it, but wanted to ping the community and see if anyone has had luck with specific brands or weights.
Old Sep 15, 2022 | 10:18 PM
altair47's Avatar
Use 5w40 and then consumption decreases. But the disease must be treated and not anesthetized.
Old Sep 21, 2022 | 05:38 PM
mossman77's Avatar
Have you opened a case with Honda of America to see if they'll cover replacement of the pistons?
Old Sep 22, 2022 | 01:36 PM
echodigital's Avatar
From TL to RDX
Acura 4G TL uses a "Syn-Blend". I would go FULL Synthetic so any 5w-20 should do. When I had the "Oil Consumption" test, they took out the Synthetic and used Syn-Blend.
Old Sep 22, 2022 | 03:20 PM
dopeboy1's Avatar
The inconvenient truth
I heard changing your oil early and often will do more than any brand or weight. It tends to burn more the more miles on the oil so don't go too long between oil changes.
Old Sep 23, 2022 | 06:37 AM
Frankyy's Avatar
2014 TL
there’s a bunch of Post on this topic
I have a 3.5 FWD now but with my old 3.7 AWD Pennzoil ultra platinum helped the most, I learned about Pennzoil from reading other posts
but every engine acts different
Old Sep 29, 2022 | 09:51 AM
JM2010 SH-AWD's Avatar
Second the notion of changing oil at 5K miles. Consumption increases as you get past 4-5K miles on an oil change cycle.
blackphenomenon
Dec 5, 2019 08:53 AM
wantboost
Nov 3, 2017 05:00 PM
burnyd
Jun 15, 2016 06:49 PM
jonnymafioso
Dec 21, 2015 04:53 AM
JEL
Aug 13, 2015 01:06 PM
